Jan 0 #1 August 3, 2004 I just picked up a used PC1, want to start using it for FF video. Sony sells a 0.6 for $80, the Royal is a 0.5 for twice the price - is it that much better, or should I look into something different? Is the Sony 0.6 wide enough for small-way FF? Quote Share this post Link to post Share on other sites
freakydiver 0 #2 August 3, 2004 For inside or outside perspective? -- (N.DG) "If all else fails – at least try and look under control." -- Quote Share this post Link to post Share on other sites
Jan 0 #3 August 4, 2004 QuoteFor inside or outside perspective? Mostly inside, sometimes outside, you know how it goes, sometimes you find yourself outside even if you meant to be inside. :-) Like I said, I just got this camera, so I want to get a lens that I can get started with. After a hundred jumps or so I'll know exactly what I want. Quote Share this post Link to post Share on other sites
AggieDave 6 #4 August 4, 2004 For my setup, I bought a .38 Keinko for my PC105. Works like a champ. I have a camera for my own personal enjoyment, for a record of my perspect of dives and to have something to trade video with other FFers. With that said, I do NOT jump a camera for money or to do outside video, its only for fun, so the .38 is perfect for me, I get to see a lot of the perspect when I'm in close.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
mr2mk1g 10 #5 August 4, 2004 You can pic up the sony lens you speek of on e-bay for as little as $20 second hand. I bought a brand new one earlier this year for $30... it arrived with a price sticker saying $80 on it. Although it says it's a 0.6 it weighs in at about a 0.43 ish depending on what you compare it against. It's certainly much wider than the numbers would suggest. Quote Share this post Link to post Share on other sites
ryoder 1,590 #6 August 4, 2004 QuoteI just picked up a used PC1, want to start using it for FF video. Sony sells a 0.6 for $80, the Royal is a 0.5 for twice the price - is it that much better, or should I look into something different? Is the Sony 0.6 wide enough for small-way FF? If you search through old postings, you will find one from LewMonst stating that in her experience, the Sony 0.60 is actually wider than other mfgr's 0.42. I have a Sony 0.60 on a PC5, and I don't think I would want anything wider."There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones. Quote Share this post Link to post Share on other sites
AndyMan 7 #7 August 4, 2004 I would do some more shopping. I saw the Sony .6 lens at Best Buy for $49.99, and on www.bhphotovideo.com for $29.99. _Am__ You put the fun in "funnel" - craichead. Quote Share this post Link to post Share on other sites
freakydiver 0 #8 August 4, 2004 For inside I use the .3 diamond: http://www.royal-lens.com/diamond_stealth.htm#diamond The nice thing about that lens is, if you know you are going to be shooting outside, you can zoom it in a little bit and decrease the field of view... For outside I use a Kenko .48 (?? I think).. -- (N.DG) "If all else fails – at least try and look under control." -- Quote Share this post Link to post Share on other sites
riggerrob 644 #9 August 4, 2004 The royal 0.3 works great on my SONY HC40. www.generationfreefly.com also supplied an adapter ring that fits perfectly. I prefer the low profile royal lens for hand-mount. Maybe there is less of a risk of snagging if you install a larger SONY lens on a helmet. Quote Share this post Link to post Share on other sites
