jasdcarter 0 #1 August 4, 2011 Has anyone jumped out of a piper cherokee 6 in a wingsuit? What was your experiance with it? Quote Share this post Link to post Share on other sites
BenediktDE 2 #2 August 5, 2011 Not done yet but it does not seem to be easy. If you get out (need door modification) there will be a massive prop blast if the pilot still has some throttle open. The stabilizer is very close and since you are standing on the wing it is relatively low as well. Did you ever jump that plane without a wingsuit? I would try that first.For every complex problem there is an answer that is clear, simple, and wrong. Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #3 August 12, 2011 We used to own one for family travel, but jumped it about ten times for demos with the rear cargo doors removed. It's a very low door, but we stacked out of it fine. I think if I were going to try to exit in a wingsuit out of it I would lay on my back with my knees up and roll to the right out the door and into the airstream making sure to keep my wings collapsed until the tail went by. I would definitely not make a habit out of it. Chuck Quote Share this post Link to post Share on other sites
