Butters 0 #26 June 24, 2011 QuoteQuoteQuoteQuoteBeing floaty is often used. But in what way are you 'floaty' If your weight is the issue, you're flying the same glide-angle as the rest of the group, and not catching up. Lacking the wingload to fly the same speed. If you're constantly overspeeding the group forward, overshooting. Than they are not flying forward enough, and need to stop using their wingsuits as camera-suits. Something a lot of people do in big wingsuits especially. Fly at okay-ish fallrates, but completely lacking forward speed. Only using their wingsuit to slow their fallrate, not using to generate forward speed. If you have more forward speed that they have. Its actually mostly their skills/flying style that are the problem...not your weight.. We all fly better when in the middle of our range. In RW (FS) weights, sleeves, swoop cords... are useful tools used to adjust the center of the range to suit the event. I see no reason why weights shouldn't be used as a range adjuster when flying a WS in a flock. I'm skinny and I'm much more comfortable in most flocks when wearing 10 - 13 pounds of lead under my wingsuit. I fly better near the top of my range. .. Define "fly". Fly a : to move in or pass through the air with wings b : to move through the air or before the wind or through outer space c : to float, wave, or soar in the air d : something I do better than you"That looks dangerous." Leopold Stotch Quote Share this post Link to post Share on other sites
kallend 2,188 #27 June 24, 2011 Quote Quote Quote Quote Quote Being floaty is often used. But in what way are you 'floaty' If your weight is the issue, you're flying the same glide-angle as the rest of the group, and not catching up. Lacking the wingload to fly the same speed. If you're constantly overspeeding the group forward, overshooting. Than they are not flying forward enough, and need to stop using their wingsuits as camera-suits. Something a lot of people do in big wingsuits especially. Fly at okay-ish fallrates, but completely lacking forward speed. Only using their wingsuit to slow their fallrate, not using to generate forward speed. If you have more forward speed that they have. Its actually mostly their skills/flying style that are the problem...not your weight.. We all fly better when in the middle of our range. In RW (FS) weights, sleeves, swoop cords... are useful tools used to adjust the center of the range to suit the event. I see no reason why weights shouldn't be used as a range adjuster when flying a WS in a flock. I'm skinny and I'm much more comfortable in most flocks when wearing 10 - 13 pounds of lead under my wingsuit. I fly better near the top of my range. .. Define "fly". Fly a : to move in or pass through the air with wings b : to move through the air or before the wind or through outer space c : to float, wave, or soar in the air d : something I do better than you No, you just plummet better than meI hardly think plummetting towards the ground at 80mph constitutes "soaring" or "floating" in anyone's mind but yours.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
mccordia 74 #28 June 24, 2011 If you go by the dictionary, everything including normal freefall can be described as flight. That aside, I think its always beautifull how you manage to get the most negative interpetation possible out of positive words other people mention. I clearly see Butters say he prefers flying at his top range (most likely flocking in the high 40's). Quote I fly better near the top of my range. Yet you somehow seem to take that the opposite, and automaticly asume he mentions freefall. You where the one complaining before about 80 mph flocks. Maybe jump with Butters a bit more...kid sure knows how to fly at speeds where the suit you wear actually has a functionJC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
OG-Tahiti 0 #29 June 24, 2011 Everyone mentions vertical speeds, and it looks like flocks are mostly in the 60-80 mph range, from what I experienced. But how about forward speed? I felt better and more precise when the flock had more forward speed for sure as all the inputs had more effect. My 2 centimes "Common sense is not so common" - Voltaire Dudeist Skydiver #9 Quote Share this post Link to post Share on other sites
Butters 0 #30 June 24, 2011 Quote Everyone mentions vertical speeds, and it looks like flocks are mostly in the 60-80 mph range, from what I experienced. But how about forward speed? I felt better and more precise when the flock had more forward speed for sure as all the inputs had more effect. My 2 centimes Speed! I definitely prefer faster forward speeds when vertically flocking ..."That looks dangerous." Leopold Stotch Quote Share this post Link to post Share on other sites
mccordia 74 #31 June 24, 2011 Definetly the more fwd speed the better. I do see the larger suits tending to be flown more on the arms, suffering from lack of glide. The higher the speed forward, the more minimal you can be in your steering inputs. The slow fallrates almost automaticly follow when a good glide/performance is flown..JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
yeyo 1 #32 June 24, 2011 Quote Quote Quote Quote Quote Quote Being floaty is often used. But in what way are you 'floaty' If your weight is the issue, you're flying the same glide-angle as the rest of the group, and not catching up. Lacking the wingload to fly the same speed. If you're constantly overspeeding the group forward, overshooting. Than they are not flying forward enough, and need to stop using their wingsuits as camera-suits. Something a lot of people do in big wingsuits especially. Fly at okay-ish fallrates, but completely lacking forward speed. Only using their wingsuit to slow their fallrate, not using to generate forward speed. If you have more forward speed that they have. Its actually mostly their skills/flying style that are the problem...not your weight.. We all fly better when in the middle of our range. In RW (FS) weights, sleeves, swoop cords... are useful tools used to adjust the center of the range to suit the event. I see no reason why weights shouldn't be used as a range adjuster when flying a WS in a flock. I'm skinny and I'm much more comfortable in most flocks when wearing 10 - 13 pounds of lead under my wingsuit. I fly better near the top of my range. .. Define "fly". Fly a : to move in or pass through the air with wings b : to move through the air or before the wind or through outer space c : to float, wave, or soar in the air d : something I do better than you No, you just plummet better than meI hardly think plummetting towards the ground at 80mph constitutes "soaring" or "floating" in anyone's mind but yours. Define "plummet" Define "better" Define "hardly" Define "soaring" Define "floating"HISPA #93 DS #419.5 Quote Share this post Link to post Share on other sites
mccordia 74 #33 June 24, 2011 If you need someone to spell it out for you, its a sign you just need to get out and fly more JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
yeyo 1 #34 June 24, 2011 Quote If you need someone to spell it out for you, its a sign you just need to get out and fly more Define "more". HISPA #93 DS #419.5 Quote Share this post Link to post Share on other sites
mccordia 74 #36 June 24, 2011 Can all be found in the dictionary, together with the word "anally retentive" JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
SuperGirl 0 #37 June 25, 2011 define anal. there, I just had to.... Quote Share this post Link to post Share on other sites
imsparticus 0 #38 June 25, 2011 or better yet draw me a picture? Quote Share this post Link to post Share on other sites
lurch 0 #39 June 27, 2011 (*) Here you go.Live and learn... or die, and teach by example. Quote Share this post Link to post Share on other sites
urowolf 0 #40 June 27, 2011 Or it could be (O). Quote Share this post Link to post Share on other sites
mccordia 74 #41 June 27, 2011 ({})JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
mnskydiver688 0 #42 June 27, 2011 Yours has ripples? I think you are using yours as more of an entrance than an exit Jarno. You should think about that.Sky Canyon Wingsuiters Quote Share this post Link to post Share on other sites
phoenixlpr 0 #43 June 27, 2011 What is wrong with you ppl? Is the weather bad? Quote Share this post Link to post Share on other sites
mccordia 74 #44 June 27, 2011 Quote What is wrong with you ppl? The have this thing most sour people always bitching on forums miss.....a sense of humor (be it a low...and here quite bad one)JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
phoenixlpr 0 #45 June 27, 2011 Quote Quote What is wrong with you ppl? The have this thing most sour people always bitching on forums miss.....a sense of humor (be it a low...and here quite bad one) Well, your kindda humor is really cool....................in the kinder garden. Quote Share this post Link to post Share on other sites
mccordia 74 #46 June 27, 2011 QuoteWell, your kindda humor is really cool....................in the kinder garden. Neeh..I tried that humor in kindergarden a few weeks back, and got arrested. Now I just display my sense of humor in that 500 meter circle around the school where I am allowed to go without being arrested...JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
mnskydiver688 0 #47 June 27, 2011 Yes, the weather has been marginal... Since Butters is the guy I "fly" with and he has been busy doing non jumping stuff, I am looking for outlets.Sky Canyon Wingsuiters Quote Share this post Link to post Share on other sites
Butters 0 #48 June 27, 2011 Quote Yes, the weather has been marginal... Since Butters is the guy I "fly" with and he has been busy doing non jumping stuff, I am looking for outlets. The weather has been less than marginal ... "That looks dangerous." Leopold Stotch Quote Share this post Link to post Share on other sites
