QuoteI just wanted to know what the general consensus is regarding relines. Should it best be left to the factory to do it or is it fine if a master rigger does it.
We do re-lines all the time in our loft...most often done by Senior Riggers. It's not hard to install a set, and there are always markings/directions to help you along.
QuoteDo master riggers make the line sets from scratch or do they order them from the manufacturer and just instal them?
Some might. Most all the riggers in our area simply buy them from the Mfg. then install them. It's a lot more work to build a set than you might think. Not some much actually building the set, but the setup to build it is time consuming. To really do it right, you need to set up a jig with all the specific measurements. Based on T&M (at least in our area) it's also significantly cheaper to buy the set from the Mfg., as they can make them much faster than most lofts can...especially if you include your setup time in your T&M.
QuoteYou could even build a main canopy from sheets, threads and paper clips, and go jumping and it would be perfectly legal.
I know this was said in a slightly tongue-in-cheek manner, but FYI, you can jump whatever you want...as long as your intent upon exiting is to land the canopy you are deploying as your "main". If you want to jump a bedsheet (literally), and don't plan on landing it, legally you must have at least 2 other canopies. The law states you must have one parachute on your back that you don't plan on using except in the case of an unforeseen emergency, and that canopy must be TSO'd (US rules).
"...and once you had tasted flight, you will walk the earth with your eyes turned skyward.
For there you have been, and there you long to return..."
QuoteLegally, a Senior or Master Parachute rigger, some under the supervision of a rigger, or the person making the nxt jump on the canopy can make minor and major repairs and alter a non-TSO'd component (main and main containe
Didn't I just read this somewhere?
Remster 30
Quotebut more directed towards the quality of worksmanship.
I wouldnt take my reserve for a repack to a rigger if I was worried about how well he could change line-sets
rmsmith 1
QuoteEither the manufacturer or a having a rigger install a manufacturer supplied line set is the way to go. Building them from scratch is simply too time consuming.
Legally, a Senior or Master Parachute rigger, some under the supervision of a rigger, or the person making the nxt jump on the canopy can make minor and major repairs and alter a non-TSO'd component (main and main container).
Derek
Actually not true. Only a Master Rigger or someone under his direct supervision(Definition of supervision is listed in Part 105.3),can alter,make major repairs, modify, or make changes to a component of a parachute assembly. It does not matter if it is a TSO'd component or not. I do not know exactly where that got started.Look under Major Repairs in the FAR's and you will find there is no distinction between the two(TSo'd ver NON-TSO'd).
A Senior Rigger's responsibilities are generally limited to Assembling, packing, and maintaining parachutes.
Line repairs are listed in the FAR's as a major repair,i.e.. I will look it up today and post the location.
Now back to the original thread.......
There are Master Riggers out there that can do great work in regards to quality and craftsmanship installing line sets and I would be glad to Pm a list of the ones that I know abroad.
Blue ones,
Mark
www.Skyworksparachuteservice.com
Hooknswoop 19
QuoteActually not true. Only a Master Rigger or someone under his direct supervision(Definition of supervision is listed in Part 105.3),can alter,make major repairs, modify, or make changes to a component of a parachute assembly. It does not matter if it is a TSO'd component or not. I do not know exactly where that got started.Look under Major Repairs in the FAR's and you will find there is no distinction between the two(TSo'd ver NON-TSO'd).
I just went through this in another forum. Check FAR part 65. I e-mailed the local FSDO and a Master Rigger/Inspector e-mailed me back that a Senior or Master Rigger, someone under the supervision of a Senior or Master rigger, the person making the next jump on the canopy, or the parachutist in command making the next jump on it, can repair/alter/major repair, etc, a main canopy or main container of a 2 canopy system. He also mentioned how (since changing how it is packed is an alteration) someone can legally change how a main canopy is packed.
Here is the e-mail I recieved from the FSDO:
"14 CFR Part 65.111(b) states, "No person may pack, maintain, or alter
any
main parachute of a dual-parachute system to be used for intentional
parachute jumping in connection with civil aircraft of the United
States
unless that person ?
1. Has an appropriate current certificate issued under this subpart;
2. Is under the supervision of a current certificated parachute
rigger;
3. Is the person making the next parachute jump with that parachute
in
accordance with 105.43(a) of this chapter;
4. Is the parachutist in command making the next parachute jump with
that parachute in a tandem parachute operation conducted under
105.45(b)(1)
of this chapter."
In plain language this regulation states:
1. If you have a parachute rigger certificate or
2. You are under the supervision of a parachute rigger or
3. You are the person jumping with the main parachute or
4. You are the parachutist in command making the next tandem jump
with
that main parachute
So, if you are any one of the above, you can pack, maintain, or alter
any
main parachute of a dual parachute system.
However, keep in mind that any main parachute alteration that affects
the
strength or operation of the auxiliary (reserve) parachute, including
the
harness, must be regarded as an alteration of the auxiliary (reserve)
parachute and must be performed by a Master Parachute Rigger using FAA
approved data.
This also answers your question that you can change how the main
parachute
is packed if you are one of the items above.
Hope this clearly answers your questions."
Part 65
Derek
Harksaw 0
From what you have said, it sounds like a Senior Rigger or the person making the jump is able to perform major repairs and alterations. I was under the impression that only a Master Rigger can perform these operations.
From FAR 65.125:
(a) A certificated senior parachute rigger may --
(1) Pack or maintain (except for major repair) any type of parachute for which he is rated; and
(2) Supervise other persons in packing any type of parachute for which that person is rated in accordance with § 105.43(a) or § 105.45(b)(1) of this chapter.
(b) A certificated master parachute rigger may --
(1) Pack, maintain, or alter any type of parachute for which he is rated; and
(2) Supervise other persons in packing, maintaining, or altering any type of parachute for which the certificated parachute rigger is rated in accordance with § 105.43(a) or § 105.45(b)(1) of this chapter.
(c) A certificated parachute rigger need not comply with §§ 65.127 through 65.133 (relating to facilities, equipment, performance standards, records, recent experience, and seal) in packing, maintaining, or altering (if authorized) the main parachute of a dual parachute pack to be used for intentional jumping.
From this, it says that you need to be a master rigger to perform major repairs and alterations. From what I have read, I have come to believe that no alterations at all can be made by a Senior Rigger, regardless of whether they could affect airworthiness. The question of whether a repair could affect the airworthiness of any of the equipment is what distinguishes between a minor (can bed done by a Senior Rigger) and a major repair(Master Rigger only).
I am not a rigger, just studying to become one, so please let me know if I am mistaken. Thanks!
I started skydiving for the money and the chicks. Oh, wait.
Hooknswoop 19
, refers to reserves/Harnesses/rserve containers. FAR Part 65.111 (b) refers to the main canopy and main container.QuoteFAR 65.125
So, only a Master Rigger (or manufacturer) can alter or make major repairs to reserves/harnesses/reserve containers. But the people listed in 65.111(b) can alter, make major repairs to the main canopy or main container.
Derek
riggerrob 644
You are getting confused over who can pack, who can do minor repairs and who can do major repairs.
My interpretation of the FARs is that a wide variety of people may PACK mains; riggers, tandem instructors or the next guy who plans to jump it.
Anything more complicated than assembly must be done by a rigger.
FAA Senior Riggers may do MINOR REPAIRS, i.e. small sewn patches.
MAJOR REPAIRS (large patches, resewing seams, relines, etc.) can only legally be done by a Master Rigger.
On a practical note, I would not entrust a re-line to anyone who had not already re-lined several canopies under the supervision of a Master Rigger.
A few skydivers have offered to "help" re-line their own canopies, but I can do the job quicker and neater by myself.
Hooknswoop 19
QuoteYou are getting confused over who can pack, who can do minor repairs and who can do major repairs.
The FAR is very specific:
any
States
rigger;
in
105.45(b)(1)
of this chapter."
with
that main parachute"
For a main parachute, if you meet one of the 4 requirements, you can "pack, maintain, or alter" it.
Derek
Quote, refers to reserves/Harnesses/rserve containers. FAR Part 65.111 (b) refers to the main canopy and main container.QuoteFAR 65.125
Derek
65.111 Certificate required.
(a) No person may pack, maintain, or alter any personnel-carrying parachute intended for emergency use in connection with civil aircraft of the United States (including the reserve parachute of a dual parachute system to be used for intentional parachute jumping) unless that person holds an appropriate current certificate and type rating issued under this subpart and complies with §§ 65.127 through 65.133.
There is no difference in 65.111 and 65.125 in regards to TSO'd equipment.
any
States
Appropiate means Master Rigger when doing Major repairs, alterations, and modifications. This is spelled out not only in the FAA written test questions, but also the DPRE test modules.
Any person can work under a Master rigger and complete the work, but the Master rigger is the one to sign it off. The intent of 65.111(b) is basically for packing and etc.
If the FSDO inspector sent that out to you; he/she needs to research further into the FAR's because they are dead wrong!
The end result is Major repairs,alterations, or modifications outside of the manufacturer, have to be done by a Master Rigger or someone under his direct supervision. And line repair is cosidered to be a major repair.
BS,
Mark
Harksaw 0
Derek
I don't see where it says 65.125 only applies to reserves. You make a very good arguement with 65.111 that anyone can do these things to the main they are jumping next (although it does not explain what an "appropriate" certificate is for performing these things on other's canopies), but it goes against everything I've been told and what I have read from the rigger's study guide I've read. So now I'm confused.
Hooknswoop 19
QuoteAppropiate means Master Rigger
Not according the Master Rigger at the Denver FSDO, that said he has delt with this issue before.
Quote1. If you have a parachute rigger certificate or
According to this inspector, who is a Master rigger, you do not even need a riggers ticket if you are jumping it next to repair or alter a main canopy.
I am not going to call an FAA inspector and tell him he is wrong.
Derek
***QuoteQuote, refers to reserves/Harnesses/rserve containers. FAR Part 65.111 (b) refers to the main canopy and main container.QuoteFAR 65.125
Derek
It can be quite confusing but do not let it get that way!
I assume that you are getting ready to take the written, and if so, stick to the reference material and you will be fine.
The Far's are in great need of rebuilding and Sandy Reid now has that project in hand. It will be a long time coming and alot of hard work ahead to complete it.
I for one would like to make them into one rating for a parachute rigger that encompasses all the ratings into one. That issue is being pushed at this time! But until then, confussion will rein!
BS,
Mark
QuoteQuoteAppropiate means Master Rigger
Not according the Master Rigger at the Denver FSDO, that said he has delt with this issue before.Quote1. If you have a parachute rigger certificate or
Derek
I will. It is not the first time an inspector/rigger has been wrong. They themselves have trouble interpreting the FAR's. They now have a "little guidebook' for interpreting the rules.
FSDO's have often had different rulings with the same FAR's between two FSDO's.
I will get him to contact you with the outcome of our discussions.
Happy Holidays,
Mark
Hooknswoop 19
any
States
rigger;
in
105.45(b)(1)
of this chapter."
4. You are the parachutist in command making the next tandem jump ***
What is your understanding of this FAR? It seems very clear to me that 1 of 4 requirements must be met to be able to legally pack, maintain, or alter a main canopy. The FAA inspector (and Master rigger) put those requirements in plain language for me.
I'll PM you his name, # and e-mail address.
Derek
riggerrob 644
I would not trust anyone to do a minor repair (i.e. small patch) unless they had a few weeks sewing practice under the supervision of a licensed rigger.
(Geeh! That sounds an awful lot like the pre-levels for FAA Senior Rigger.)
And I would not trust anyone (outside a factory) to re-line a canopy unless they had 2 or 3 years experience doing major repairs - under supervision.
(Geeh! That sounds an awful lot like the pre-levels for FAA Master Rigger.)
QuoteWe can argue the finer points of the written law all week, but the bottom line is that I don't trust most skydivers to "assemble" their own mains.
I could not say it any better! This year alone we have had at least three (3) mis-riggings that almost killed someone from "Field Rigging". They all were Senior Riggers with limited knowledge and experience that got their hands on a line set.
No matter what, you have to have the knowledge and equipment to do the Job right.
Blue Ones Guys,
Mark
a.k.a "M.E.L"Skyworks Parachute Service, LLC
Hooknswoop 19
I agree
Derek
riggerrob 644
Derek
Hee! Hee!
Were you referring to all the little Latina ladies who do the real production work in most parachute factories?
I have the utmost respect for ladies like Consuelo and Lita etc. They have far more patience than me sewing beautifully year in and year out.
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/WebSearchDefault?SearchView&Query=ac%20105-2c&SearchOrder=1&SearchMax=0&SearchWV=TRUE&SearchFuzzy=FALSE&Start=1&Count=100#
Go to page 8 of 18 and then paragraph 12.
The ruling for alterations to main parachutes is forth coming from Washington and will be posted when I receive it. It has not changed!
Mark
Derek
