tlipiec 0 #51 January 31, 2016 Luke, I'd also fancy a link if that's possible. Cheers :)# 2092 Stay away from the rivers Quote Share this post Link to post Share on other sites
Geo-Log 0 #52 January 1, 2017 Hi Luke, Could you please send me a new version with changeable config option too Thanks in advance Quote Share this post Link to post Share on other sites
tlipiec 0 #53 February 8, 2017 Michael from FlySight emailed me a link to FlyBlind software update from 04/2016 that includes the selectable configuration, which is absolutely awesome! Finally I can switch between different DZs or modes on the go without need of a laptop :) http://flysight.ca/fw/flyblind-20160404-win.zip# 2092 Stay away from the rivers Quote Share this post Link to post Share on other sites
voilsb 1 #54 July 14, 2018 How do you guys have flyblind configured? I'm trying to get it to give me verbal distance, tone rate for how close my heading is to the target, and high/low pitches to indicate left or right to get on heading. I can get the first two, but not the third.Brian Quote Share this post Link to post Share on other sites
dthames 0 #55 July 16, 2018 I will have to search but I think I have a config for that. It has been a while since I used Flyblind.Instructor quote, “What's weird is that you're older than my dad!” Quote Share this post Link to post Share on other sites
voilsb 1 #56 July 22, 2018 I'm just playing with it for now. Mostly as a learning exercise. Decided to finally mount and use my flysightBrian Quote Share this post Link to post Share on other sites
dthames 0 #57 July 24, 2018 voilsb I'm just playing with it for now. Mostly as a learning exercise. Decided to finally mount and use my flysight I listen to my vertical speed, once every 3 seconds. Post breakoff, I try to see how slow I can get my vertical, just playing around. I get better and better, beyond what I ever thought that I could do.Instructor quote, “What's weird is that you're older than my dad!” Quote Share this post Link to post Share on other sites
Yorick 0 #58 October 24, 2018 voilsb How do you guys have flyblind configured? I'm trying to get it to give me verbal distance, tone rate for how close my heading is to the target, and high/low pitches to indicate left or right to get on heading. I can get the first two, but not the third. ; Firmware version ; For information on configuring FlySight, please go to ; http://flysight.ca/wiki ; GPS settings Model: 6 ; Dynamic model ; 0 = Portable ; 2 = Stationary ; 3 = Pedestrian ; 4 = Automotive ; 5 = Sea ; 6 = Airborne with < 1 G acceleration ; 7 = Airborne with < 2 G acceleration ; 8 = Airborne with < 4 G acceleration Rate: 200 ; Measurement rate (ms) ; Tone settings Mode: 5 ; Measurement mode ; 0 = Horizontal speed ; 1 = Vertical speed ; 2 = Glide ratio ; 3 = Inverse glide ratio ; 4 = Total speed ; 5 = Direction to destination ; 6 = Distance to destination ; 7 = Direction to bearing ; 11 = Dive angle Min: 0 ; Lowest pitch value ; cm/s in Mode 0, 1, or 4 ; ratio * 100 in Mode 2 or 3 ; degrees in Mode 11 Max: 300 ; Highest pitch value ; cm/s in Mode 0, 1, or 4 ; ratio * 100 in Mode 2 or 3 ; degrees in Mode 11 Limits: 1 ; Behaviour when outside bounds ; 0 = No tone ; 1 = Min/max tone ; 2 = Chirp up/down ; 3 = Chirp down/up Volume: 4 ; 0 (min) to 8 (max) ; Rate settings Mode_2: 6 ; Determines tone rate ; 0 = Horizontal speed ; 1 = Vertical speed ; 2 = Glide ratio ; 3 = Inverse glide ratio ; 4 = Total speed ; 5 = Direction to destination ; 6 = Distance to destination ; 7 = Direction to bearing ; 8 = Magnitude of Value 1 ; 9 = Change in Value 1 ; 11 = Dive angle Min_Val_2: 300 ; Lowest rate value ; cm/s when Mode 2 = 0, 1, or 4 ; ratio * 100 when Mode 2 = 2 or 3 ; percent * 100 when Mode 2 = 9 ; degrees when Mode 2 = 11 Max_Val_2: 1500 ; Highest rate value ; cm/s when Mode 2 = 0, 1, or 4 ; ratio * 100 when Mode 2 = 2 or 3 ; percent * 100 when Mode 2 = 9 ; degrees when Mode 2 = 11 Min_Rate: 100 ; Minimum rate (Hz * 100) Max_Rate: 500 ; Maximum rate (Hz * 100) Flatline: 0 ; Flatline at minimum rate ; 0 = No ; 1 = Yes ; Speech settings Sp_Mode: 6 ; Speech mode ; 0 = Horizontal speed ; 1 = Vertical speed ; 2 = Glide ratio ; 3 = Inverse glide ratio ; 4 = Total speed ; 5 = Direction to destination ; 6 = Distance to destination ; 7 = Direction to bearing ; 11 = Dive angle Sp_Units: 1 ; Speech units ; 0 = km/h ; 1 = mph ; 2 = kn Sp_Rate: 7 ; Speech rate (s) ; 0 = No speech Sp_Dec: 1 ; Decimal places for speech (0-2) ; (Sp_Modes 0-4) Sp_Volume: 3 ; 0 (min) to 8 (max) ; Thresholds V_Thresh: 0 ; Minimum vertical speed for tone (cm/s) H_Thresh: 0 ; Minimum horizontal speed for tone (cm/s) ; Miscellaneous Use_SAS: 1 ; Use skydiver's airspeed ; 0 = No ; 1 = Yes TZ_Offset: 3600 ; Timezone offset of output files in seconds ; 3600 = UTC+1 (IST, BST) ; -14400 = UTC-4 (EDT) ; -18000 = UTC-5 (EST, CDT) ; -21600 = UTC-6 (CST, MDT) ; -25200 = UTC-7 (MST, PDT) ; -28800 = UTC-8 (PST) ; Initialization Init_Mode: 1 ; When the FlySight is powered on ; 0 = Do nothing ; 1 = Test speech mode ; 2 = Play file Init_File: 0 ; File to be played ; Alarm settings ; WARNING: GPS measurements depend on very weak signals ; received from orbiting satellites. As such, they ; are prone to interference, and should NEVER be ; relied upon for life saving purposes. ; UNDER NO CIRCUMSTANCES SHOULD THESE ALARMS BE ; USED TO INDICATE DEPLOYMENT OR BREAKOFF ALTITUDE. ; NOTE: Alarm elevations are given in meters above ground ; elevation, which is specified in DZ_Elev. Win_Above: 0 ; Window above each alarm (m) Win_Below: 0 ; Window below each alarm (m) DZ_Elev: 0 ; Ground elevation (m above sea level) Alarm_Elev: 1000 ; Alarm elevation (m above ground level) Alarm_Type: 0 ; Alarm type ; 0 = No alarm ; 1 = Beep ; 2 = Chirp up ; 3 = Chirp down ; 4 = Play file Alarm_File: 0 ; File to be played ; Silence windows ; NOTE: Silence windows are given in meters above ground ; elevation, which is specified in DZ_Elev. Tones ; will be silenced during these windows and only ; alarms will be audible. Win_Top: 0 ; Silence window top (m) Win_Bottom: 0 ; Silence window bottom (m) ; Flyblind settings Lat: 531182640 ; Latitude of destination (Deg *10,000,000) Lon: +48289934 ; Longitude of destination (Deg *10,000,000) Elevation: 1 ; Elevation of destination (m) Bearing: 0 ; Bearing to follow (Degrees) (Mode 7) ; Flyblind silence settings End_Nav: 0 ; Minimum height above DZ_Elev (m) for tone or speech (Modes/SP_Modes 5 & 7) ; 0 = Disable ; Max value = 3000 Max_Dist: 0 ; Maximum distance from destination (m) for tone or speech (Mode/SP_Mode 5) ; 0 = Disable ; Max value = 10000"The 'perfect' parachute jump was thought to be one where the opening shock and touchdown were simultaneous" -Lyle Cameron, ~1965 --- Falling-With-Style.com Quote Share this post Link to post Share on other sites
