shropshire
Vertical Speed indicator - good idea?
Hi, I've just started flying wing suits (and loving it) but also fly Paragliders.
The main instrument that I use when PGing is a Variometer, which not only gives me altitude but also Vertical Airspeed.
I'm thinking, that maybe I can convert one of my old ones by recalibrating it so that in stead of VS differences based around 0 m.p.h +ve/-ve it gives me speeds centred around (say but adjustable) 70m.p.h.
This centred speed (stready flight) could be adjusted as I improve.
Once set, the device would give me audible signals (as it does now) if I slow down (happy signal) or speed up vertically (sad signal).
Would this be a usefull training tool?
(.)Y(.)
Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome
We were talking about this in Kamloops last weekend and one of the points of discussion was the Viso and the Speed Meter mode. According to the manual:
Speed-Meter Mode
When the VISO is set to Speed-Meter mode, the “ALTI”, “Feet/Meter”, “Mph/Kmh” and “TAS/SAS” icons are ON.
Note: The VISO will display the altitude during climb and switch to Speed-Meter during the freefall and under canopy. Date/Time area switches OFF during the freefall and under
canopy.
Speed-Meter Display during the freefall Speed resolution is in 1 Mph (1 Kmh) increments.
Important Notice about Speed Recordings:
Experience has shown that when mounting the VISO on the hand or belly, different air pressures induced by hand or body movements may result in incorrect recordings of speeds.
I did not get a chance to try it but I am planning on getting one and mounting it to my Ringsite to see if it is a viable alternative to making one. I am hoping to do this next weekend but we will see if I can get my hands on one before then...
Scott C.
"He who Hesitates Shall Inherit the Earth!"
It may be useful some time to attach 4 or 5 of the same devices to a flyer so the we can actually gain some imperical data about this 'difference' in pressures at different parts of the body during a flight... let's see how much difference ther actuall is and then where best to locat the pressure sensors in the future.
(.)Y(.)
