caldefly
wingsuit fit
i just bought a brand new phantom wingsuit custom made, it feels a little bit too tight and i can barely zip the leg bootie. i have to stand up to be able to put it on. ( the legbootie ) Is this right? is there a fix ? or do i neeed to send it back to the factory?
" THE SKY IS THE LIMIT "
ok. i tought you should be able to zip the booties while still sitting on the plane . I saw a jumper zipping his booties on a tony suit and is probably due to the design.or maybe he had a larger size . But now that you tell me i know my suit is ok. the other issue is zipping the leg bootie is still dificult because it is too tight... I live like about an hour from zephyrhills , fl . so i guess i will go and have some one take a look at it. thanks for the info unclecharlie it was great help
