Chuck
The111 1
QuoteCome on Matt.
You know better than that. 10 kg heavier person is a thicker air foil. Shorter increases Aspect ratio by how much? A few hundredths.
No, I don't. That was my point. We are NOT super-efficient airfoils, most of us are gliding at LESS than 2:1 most of the time. Jeff Nebelkopf made a SINGLE SKIN suit and could glide well enough to keep up with people pushing it harder in inflatable suits. A very subtle airfoil change is incredibly negligible, compared to all the other factors that determine your G.R.
And another look at the height thing. A shorter person is not only shorter, but narrower (arm and legspan). So they are basically a "scaled down" version of the tall person. Why should a scaled down version glide any less well than a larger version? That's like saying that a Spectre 170 can glide flatter than a 120.
Macthe 0
QuoteQuoteCome on Matt.
If you had an F16 that flew at 1000mph
then scaled it down till it weighd an ounce, there would be no way it could go as fast,
it seems to me
KrisFlyZ 0
Just trying to say this...
Get a suit too big and your performance, consistency will suffer. We can stretch our body to an extent and fill out a suit that is slightly big, a few more inches bigger and it becomes impossible to fly it at the same efficiency as the suit that fits us well.
Kris.
Chuck
KrisFlyZ 0
This is the explanation I have in my mind...may not be right....
Jeff N, flying almost as well(or better) as the others in the single skin suit.
Can you guarantee that the flight is at a super efficient AoA? My bet is that it is in a stally configuration....
AoA = ATAN(D/L) (-/+) pitch (-/+) Angle of Incidence
AT 2:1 GR this is 26.5 degrees(at lower glide the angle is even bigger)....at this AoA, the double skin suit will effectively become a single skin suit of lesser area.
QuoteAnd another look at the height thing. A shorter person is not only shorter, but narrower (arm and legspan). So they are basically a "scaled down" version of the tall person. Why should a scaled down version glide any less well than a larger version? That's like saying that a Spectre 170 can glide flatter than a 120.
Can't answer that theoritically.
Kris.
The111 1
QuoteIf you had an F16 that flew at 1000mph
it seems to me
I was not talking about speed. I was talking about glide ratio. The word "fast" cannot describe a glide ratio.
Moreover, we are not talking about scaling factors that large. We're talking about maybe 10-20% size changes in the human body.
QuoteThat's like saying that a Spectre 170 can glide flatter than a 120.
A Spectre 170 does glide better than a Spectre 120. Scaling is a difficult challenge.
Ted
Like a giddy school girl.
KrisFlyZ 0
Will the same person if he was 5 inches shorter and 10kg heavier make a poorer glider than the original?
Kris.
robibird 3
 He is 178 tall and 98 kg heavy
robert@phoenix-fly.com
www.phoenix-fly.com
-hot small wingsuit girl : above my credit limit
