Macthe 0
Actually this is not true. It takes very little air leaking up into your upper camber surface to absolutely kill any lift.
but ive heard of wing's that "leak" air to create better laminar flow??
I used to fly sailplanes
, they killed the lift by blocking off the top of the wing, not leaking air. Hell, the wing of a modern glider is so finely tuned that even something as small as droplets of water on the top surface brings a noticeable change in performance. I don't think wingsuits are that good yet.
Those are called critical laminar flow. Have you seen the spoilers on some "fast glass" homebuilts? Not the aspect ratio of the long sleek glider wings but in some regards just as critical. Some of those have spoilers the size of a sandwich and are very effective.
You may be confusing this with an airfoil that is designed to be "turbulated". More effective use of lift at slower speeds with a lot of spanwise segments. Kind of like some ultralights.
Or you may be referring to the texture of most supersonic aircraft that is somewhat textured and not smooth. This keeps the first boundary layer energized and not so sticky.
What I'm refering to is the definitive loss off lift in my S3 that was backvented and airlocked compared to a very similar sized straight production model. Imagine an S3 that never has any arm strain, ever. The reason was that the pull from lift was never great enough to be felt by the human arm on the backvented model. And the kicker was that good flockers can always fly their regular non-backvented wingsuit on their backs very efficiently. I got tons of video of this.My V-2 is of course non vented but I have flown it for a few moments inverted just fine.
I love the ACRO and want one. I have not tested the Phacro which offers a non-vented version the phantom to compare. I would love to test the "air tightness" of the Blade.
pbla4024 0
Not leak, but suck. Put bunch of tiny holes to surface of wing and apply vacuum to suck air into wing.
Fido
aarthus 0
Just a question about the the blade's leg wing ! It is said that " Leg wing is totally new and 15 cm wider than the S6 " but when you look at the birdmantopgun pictures, it look like it's the opposite ! the leg wing and the defector appears to be smaller ! is it a visual effect ? the size of the back deflector is maybe longer ?
thanks !
thanks !
Patrick de Guillebon
QuoteJust a question about the the blade's leg wing ! It is said that " Leg wing is totally new and 15 cm wider than the S6 " but when you look at the birdmantopgun pictures, it look like it's the opposite ! the leg wing and the defector appears to be smaller ! is it a visual effect ? the size of the back deflector is maybe longer ?
thanks !
As far as I understand the topgun pics show prototypes, not the massproduction model.
mccordia 74
The legwing on the prototype we flew in spain was attached to the back of the leg, and enabled you to roll your ankles out 90 degrees, and use the booties as part of the wing. Giving you a large surface area. When flocking, your feet are down, and you have your legs hanging underneath the wing as 2 stabilsing rudders..
But the max flying position felt so weird (and difficult to hold), and the wing on the back of the legs also gave you less feeling on what the wing was doing, that we went back to the 'classic' S6 style legwing (attached to the front of the leg) that was on earlyer prototypes, which you now you see on the production model.
JC
FlyLikeBrick
I'm an Athlete?
FlyLikeBrick
I'm an Athlete?
aarthus 0
It makes more sense ! Looks really good this new model ! will it be possible in future to try one ? and what about the colors ? will it be possible to choose your own out of those presented on the site ?
