KrisFlyZ 0 #1 September 12, 2006 Just to check a statistical theory I have ...need some data. Your height and arm length(minus the hand). Height : 6'2" Armlength: 25" Kris. Quote Share this post Link to post Share on other sites
JohanW 0 #2 September 12, 2006 Yes, that sounds about right Can I have my hand back now? How do you measure that, on the top or on the bottom of the arm?Johan. I am. I think. Quote Share this post Link to post Share on other sites
Costyn 1 #3 September 12, 2006 Yeah, and from what part of the shoulders? Or under your arm-pits? Do you accept metric values? Or do I have to convert them to your silly outdated American system before submitting them? Costyn van Dongen - http://www.flylikebrick.com/ - World Wide Wingsuit News Quote Share this post Link to post Share on other sites
LouDiamond 1 #4 September 12, 2006 Where are you measuring the arm from(start/finish point)? Having measured a lot of people for suits, I can honestly say there is a vast difference in heights and arm measurements from person to person. I've measured people as small as a 4'8" female and as large as a guy in the 6' 9"+ range. As for a middle ground I really don't think there is one unless you consider middle ground the 5'6" to 6' range as thats where most males and females usually fall. Arm length is as varied as well. Looking at several past order forms I have multiple arm mesurements starting at 70cm all the way up to 82cm. The only numbers I didn't see were 71 and 78. Every other measurement had at least 2-3 people within that numerical range. If I had to pick a median number I would have to say it looks to be in the 75-77cm range. If you look at Da Vinci's golden ratio or divine proportions on things you will find that there is a proportional balance that can be applied to a human being as well as everything else in the world just about. According to this, the length of a mans outspread arms is equal to his height. However, we all know that some people either have appendages that are either slightly longer or shorter than others so this may not always be an absolute but its pretty damn close.Which is why this is considered to be an "average" or "ideal" interpretation of the human form."It's just skydiving..additional drama is not required" Some people dream about flying, I live my dream SKYMONKEY PUBLISHING Quote Share this post Link to post Share on other sites
KrisFlyZ 0 #5 September 12, 2006 Yes, just like you would measure for a wingsuit....thanks Scott . The median range seems to be 27.6 thru 32.3 inches. Metric system is fine Costyn . Kris. Quote Share this post Link to post Share on other sites
stayhigh 2 #6 September 12, 2006 and also elbow is size of your feet Just random infoBernie Sanders for President 2016 Quote Share this post Link to post Share on other sites
kallend 2,185 #7 September 13, 2006 Quote all the way up to 82cm. That would be me. Clearly descended from gibbons.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
saly 0 #8 September 13, 2006 Talking proportions. I figure there are a number of different proportions that effect wing suit flight characteristics. Height to body mass ratio Crotch to toe length/body length Arm length Male or female relating to C of G (shoulder hip thing) Is there amy indication of which is/are the optimum for wingsuiting? --------------------------------------------- If you don't have wings you will never fly Quote Share this post Link to post Share on other sites
KrisFlyZ 0 #9 September 13, 2006 This is not to determine what bodytype makes for a better flyer. Just curious if short torso means shorter arms as well. I have a 26.5" inch torso(measured along the body instead of straight down), the arms (as measured for the wingsuit ) end about the same height where the inseam measurement starts. In other words the arm length equals torso length? approximately? People what to test this out and post your findings here? Prof, What is your torso length? Kris. Quote Share this post Link to post Share on other sites
phoenixlpr 0 #10 September 13, 2006 AFAK most of the lift is coming from the leg wing. Tall and skinny people are said to be the best wingsuit fliers. Quote Share this post Link to post Share on other sites
plankton 0 #11 September 13, 2006 Quote Height : 6'2" Armlength: 25" Kris. I have just made my order for V-2 and I have exactly the same measurements as you. Height : 6'2" and Armlength: 25". I have measured myself according PF measurement guide. They count lenght of the arm from the shoulder to bone of wrist Quote Share this post Link to post Share on other sites
KrisFlyZ 0 #12 September 13, 2006 QuoteAFAK most of the lift is coming from the leg wing. Tall and skinny people are said to be the best wingsuit fliers. QuoteThis is not to determine what bodytype makes for a better flyer. Having said that...how can you say most lift is coming from the legwing? A person with a longer torso than legs will have much more combined arm wing area and thus get more lift from those wings. I have long legs and from a wing area prespective, what you say is true. For example : My V2 leg wing area is approximately 756 sq inches(including the legs) and the combined arm wing area is 546 sq inches(including arms and leading edge). If we calculated the same for someone with the same dimensions as me but with Kallend size arms...will have 864 sq inch arm wings and a 756 sq inch leg wing. Kris. Quote Share this post Link to post Share on other sites
KrisFlyZ 0 #13 September 13, 2006 What is your Torso length(body measurement) and Inseam? Just trying to find my body double . Scott, an average small arm length of 70 cm seems big. I compared some small, medium and large size shirts and the arm lengths did not vary that much. I can wear a medium or a large and the arm length is not 6-7cm big. Kris. Quote Share this post Link to post Share on other sites
plankton 0 #14 September 13, 2006 Kris if you need here is my body measurements. It is not a secret 1. height 189cm 2. chest 104 3 waist 93 4. hip 107 5 shoulder to the floor 158 6 body 77 7 inseam 92 8 shoulder 48 9 arm 64 10 thigh 61 11 bicep 33 12 wrist 18 13 shoe size US 11 14 weight 90 kg I usually wear XL shirt Does the way that PF measures differ from Birdmen? Quote Share this post Link to post Share on other sites
kallend 2,185 #15 September 13, 2006 Quote Prof, What is your torso length? Kris. measured between which points?... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
phoenixlpr 0 #16 September 13, 2006 QuoteFor example : My V2 leg wing area is approximately 756 sq inches(including the legs) and the combined arm wing area is 546 sq inches(including arms and leading edge). If we calculated the same for someone with the same dimensions as me but with Kallend size arms...will have 864 sq inch arm wings and a 756 sq inch leg wing. So? AFAK you set the your agle of attach by the ratio of the lift generated by the arm and the leg wing. So you might have bigger arm wing or leg wing area, but it could not be effective. Quote Share this post Link to post Share on other sites
chris74 0 #17 September 13, 2006 Hi Birds, For me 19 cms when ready ! Blue skies Chris PS like you kris because your ex V1 fits me like a glove ( after some minor sewings. ) Quote Share this post Link to post Share on other sites
KrisFlyZ 0 #18 September 14, 2006 QuoteQuote Prof, What is your torso length? Kris. measured between which points? Sorry, just like it is measured for a wingsuit(from the point where the four seams of the trousers meet to the point where a round neck t-shirt would meet the neck). If I remember correctly, you have long legs and a shorter(relative to legs) torso. Kris. Quote Share this post Link to post Share on other sites
KrisFlyZ 0 #19 September 14, 2006 No, I am just saying that some people might have bigger arm wings. Whay are you saying that most lift comes from the leg wing? Kris. Quote Share this post Link to post Share on other sites
KrisFlyZ 0 #20 September 14, 2006 Hi, I think PF has a few extra measurements like body. I am almost exactly like you in measurements. I am 2 cm shorter, my body measurement is 4 inches shorter and the inseam is about 3/4 inch longer. I don't know if my suit would fit you but your suit would fit me. Kris. Quote Share this post Link to post Share on other sites
