Waldschrat
repair
My V1 needs repair in the factory, because the right armwing is damaged. (They must exchange the wing)
I have send the suit to the factory for ca. 8 weeks. [:/]
My questions are: Have you also a wingsuit in factory-repair in the past?
How long does ist goes bevor your suit cam back?
Wich suit was it?
What was damaged?
Many thanks
waldschrat
I had your problem last year, i broke the left wing of my V-1 during exit due to a jam between the wing and the plane door.
Maybe i'm a bit lucky 'cause UncleCharlie lives not far from me and i gave him the suit.
It tooks about 1 month to reach the factory, re-build the wing and return back.
just send a P.Message to Unclecharlie to ask about your suit, i'm shure he will help !
Marco "Pazzo" Pistolesi
pistolesi.marco(at)gmail.com
I had to send my S3S back to Bird-Man about a month back because there was a tear in the wing. I'm not sure of the cause, but probably my own fault. The deflector had probably gotten caught behind something and made a rip.
I sent it to the Bird-Man factory and I got it back 4 weeks later, which I thought was a reasonable time.
Cheers,
Costyn.
Costyn van Dongen - http://www.flylikebrick.com/ - World Wide Wingsuit News
I brought my S-Fly (1st generation) to Loic because the fabric was tearing apart (no double stitching, no hemming) when we met first time in Lapalisse. Received a brand new suit 4 seconds later. :)
scissors beat paper, paper beat rock, rock beat wingsuit - KarlM
I once sent a suit back to the manufacturer, and although the cost of repair was OK, and I had it back within 6 weeks (I live in Africa..) since then I have managed to get riggers here to do all repairs.
The logic is simple. If the manufacturer is going to replace the wing, then a local rigger CAN'T screw it up beyond trying. They've since managed everything from rib replacement to replacing booties or thumb loops etc.
What do you have to lose?
t
It's the year of the Pig.
