YISkyDive
GPS questions.
OK guys- Sorry to make Another GPS thread but I have completely confused myself.
I currently wish to take a GPS into freefall for canopy control logging, and my smoke pants project.
I know wingsuiters have been taking GPS units into freefall so I have done a search but managed to mangle my poor brain more than help it.
The goals of my project are to learn the vertical (accomplished w. Neptune) and horizontal speeds of different maneuvers above pattern entry altitudes. Its more or less for fun and reference, but I do not know what unit to get and more so what software is gonna assault my wallet.
The second goal is to track a regular track dive, jumpsuit with booty dive, and two different smoke pants I have made to see what speeds I am reaching. My videos show an immense difference in ground speed between the four, so I wanted to some hard figures to work with.
I want a GPS that can act as a stand alone unit. I wish not to take my pocket PC into freefall for obvious reasons. My current plan is to mount the recording unit onto my leg but I’ve heard other mounting positions are recommended first.
I also wish to use the unit to record my ski/ snowboard top speeds. I’m assuming the unit wingsuiters use can do this.
Thanks for your time guys, id really appreciate any help, and sorry about yet another thread. The search confused me more than helped.
-dave.
I use the Garmin Etrex Vista, the Garmin V and the Garmin Foretrex with good results. The Etrex is a good choice if you want to see your glide ratio in real time as it has a glide ratio screen you can have displayed with other selectable fields. For your application, mounted on your chest, you could get real time feedback.
The Foretrex is great because it's basically like a wrist watch and is the cheaper of the 2. I recommend both but buy what your budget allows for.
As for actual analysis of your data, there is hands down nothing better to compare the hard figures you want than with Paralog's new GPS version software. All of the data you could possibly want can be graphed and displayed for later analysis. See it HERE
Depending on which GPS you decide to go with , your looking at about a $200-$300 total cost for GPS and Software.
SKYMONKEY PUBLISHING
Thanks for all the usefull help gents!
I think i am decided on going for the Foretrex 201.. All i really need is a logger that can do realtime logging.. so the Vista seems over kill since im not concered with terrain relation.
If anyone has any comments on their foretrex 201s id love to hear em. I do plan on wearing it as a wrist watch.
Also do you turn the unit on, on the ground? Like before boarding?
Thanks guys,
I appreciate the help
-Dave
Yes, you need to give it time to acquire satellites. A cold start may take a significant amount of time to acquire satellites where as a warm start takes little to no time to reacquire.
Any unit that have can track points continuously and then transfer to your PC is good. When I got mine I got the cheapest one: foretrex 201. But it's a little slow, only one point per second logged to the track. But it's enough for me. If the unit you're gonna buy have barometric altimeter is also a plus so the altitude logging will be more precise. But since you already have a neptune...
Paralog is the best for analyzing the data for now, but I also use CompeGPSAir that can replay the jump with a 3D animation.
Leo Holanda
...But it's a little slow, only one point per second logged to the track.
Does anyone know what the GPS with the smallest track interval available is? Or what the minimum track intervals are for the various GPS units on the market?
If you could find something that could record in very small intervals (10ths or 100ths of a second, I'd think) you could do some interesting stuff with openings.
-- Tom Aiello
Tom@SnakeRiverBASE.com
SnakeRiverBASE.com
They are available however they are very expensive. You can check on gpsworld.com for the most in depth look at GPS systems and you can look at one desgined for the canopy manufacturers HERE Total cost for the datalogger and software is $10k
For consumer GPS's, with their accuracy 3-10ft, data recorded in such small intervals will be too "noisy".
Yup, I used to have the logger set at 1 sec. The best number I have seen on the screen as far as accuracy goes is 7 ft. If logging at 1 sec intervals, a 1 sec interval will yield an error of atleast 14 ft(for 1 sec = 14fps) error or for 100 fps(68 mph) total speed the error is 14 percent or higher.That is too high.
The same numbers if logged at 3 secs yield an error of 4.4 percent or higher.
Kris.
Kris,
Based on my experience, the spatial resolution and accuracy does not directly impact speed accuracy. Although your absolute position might not be accurate, two consecutive positions are usually quite accurate compared to each other, i.e. the position does not 'jump'.
You can verify this with this simple experiment: Switch on your GPS receiver and stand still. Although your unit might report an accuracy of 'only' 7ft, your measured and displayed speed will usually be zero.
This chart demonstrates what I mean.
Klaus
My Logbook
maybe not the quickest there is, but i've used one logging at 5 hz. the accuracy was amazing. though i never had anything to compare the actual accuracy to, as mentioned, what you want is relative accuracy. it has only bee used for basejumping, but small variations in flying performance were very noticeable. opening characteristics too. also movement on the exit down to half a meter is very noticeable. but it wasn't made for jumping or any other sporting activity, and was very bulky and impractical. i have been looking for a gps that logs quick, but 1 hz is the quickest i've seen around.
i don't believe increased logging speed will make it more inaccurate. what it does is it makes it possible to see the errors that occur, and then you are able to manually correct them later if you'd like. for example, if you log at 100 hz and you trace your log suddenly you have ten feet between two points, you can adjust this. but if you log at 1 hz, because your points would typically be 100(ish) feet apart, an offset of ten feet is undetectable.
using this 5 hz logger i've often seen these offsets occuring, in the range of 10-20 feet.
because of the bulky impracticality of the gps i used, i have been looking for something smoother with the same update and logging speed. not having found anything in this range, the project now is to assemble one...
Sorry for the stupid question, i've buyed the foretrex 101 and i've got a problem I really can't track the satellites while i'm in the aircraft !
If i turn it on while standing on the ground it align correctly with the sats, i wait one or two takeoff (40 mins) and then when i board for my load the foretrex can't "listen" for sats anymore... I tried to give it to the pilot who putted on the copickt i've tried in a Turbo Finist and in a PC-6 Pilatus too, same problem...
When i exit from the plane it took too much time to re-align with sat (5 mins) and so...
This can't be the right way, do you have any suggestion ?
Marco "Pazzo" Pistolesi
pistolesi.marco(at)gmail.com
Marco,
this is not a stupid question at all! Although I have no personel experience with a Porter or Finist, I have succesfully used the ForeTrex 101 through the windows of other planes and cars.
Actually, the big front window of the Porter should be ideal as it gives you a clear view of more than half of the sky. I can think of two possible reasons creating the problems: The windshield might be metal-covered as insome cars or the built-in GPS or some other on-board electronis create interference.
What happens if you try to get a satelite fix through the front window on the ground with all electronics switched off? Would a re-radiating antenna be an option?
Does anybody else have some good or bad experience or background information on using GPS in a Porter?
Klaus
My Logbook
putting the gps under the front window let it acquires some sats, but when we are 1 min to go (red light) i have to start prepare myself and.... zip, helmet, gloves, eye, camera, gps, checks... ok, "exit exit"... first RW4 (10 sec), 2 people in Freefly (6 sec) and last an AFF (15 sec) it's my turn... but in this little period of time the sats are all lost...
Glad to hear this. So it's not the Porter or it's windshield! It is an unfortunate fact that GPS signals can not be received in buildings, forests(!), cars and planes without a clear view to a larger part of the sky.
Nevertheless - without going into the technical details - short interruptions of satelite reception should result in a 'hot fix' with a re-aquisition time of less than 15 secs.
What can you do to improve the situation? Keep a satelite fix as long as possible, be quick getting to the door, get a new fix while waiting in the door. When jumping a Porter, can't you just do a diving exit directly from the co-pilots seat out of the door? This should keep the interuption to a minimum. ;-)
HTH,
Klaus
My Logbook
While some vehicles have windshields that prevent GPs signals from being received, I am not aware of any aircraft windshields being that way but it is possible.
However, I don't think that is the root of your problem. The foretrex is a small receiver with an internal antenna and a small power source. All GPS receivers must be able to "see" the satellites in order to get a fix. Some are capable of being out of contact for a few moments and based on the information it received from the almanac when it was receiveing signals, can predict where the satellites "should" be when it is able to see the sky again. I think the problem you're experiencing is one we all encounter when inside an aircraft with a GPS. Depending on what I am doing, I sometimes use the external antenna on my Garmin GPS V and mount it out side with the attached magnet. I have full coverage from ground to altitude that way. Since you do not have an external mount on your receiver your only option is to use a re-radiating antenna so that you maintain GPS signal inside the aircraft. You can find battery powered ones if you look around but most come with the 12 volt cigarette adapter plug. They are not too expensive and they work great for GPS receivers with no external mounts or when working inside an enclosed area.
if you mount GPS on your chest, does it see satellites? Did anyone try to mount Etrex Vista on your chest and see the altitude vs. distance plot in real time?
I wear my Vista on my chest strap and it still picks up satellites. I make sure to stand outside the aircraft(otter) after the last skydiver exits so I can reaquire sats before I exit. Ocassionaly, I will loose a bit of data on the top end but overall, I still get the meat of the flight.
Thanks, Lou. How do you mount Vista on your chest strap?
I use one of the aftermarket cases made out of neoprene for use on the water. It has a clear piece of plastic so you can see the face and it closes with a pretty strong piece of velcro on the 1 flap. The back of it has a sewn belt style loop that I route my chest strap through.
