Shivon 0 #1 October 8, 2003 Quick question - does anyone know what the original line type was with the PD280? I assume it was Kevlar? When doing a reline, would it be possible to use a different line type (like spectra, etc). Quote Share this post Link to post Share on other sites
skybytch 273 #2 October 8, 2003 Depends on which type lines the original purchaser put on it. Most likely microline (spectra) or Dacron. AFAIK, PD has never offered Kevlar lines. Quote Share this post Link to post Share on other sites
riggerrob 643 #3 October 8, 2003 Forget about Kevlar lines on main canopies. You cannot trust them for more than 40 jumps. Sure, a few reserves (i.e. Strong 425) were built with Kevlar lines, but have you noticed that we retire them after 20 deployments? You would be far wiser to re-line your PD-280 with 800 pound Spectra suspension lines. Quote Share this post Link to post Share on other sites
Shivon 0 #4 October 9, 2003 QuoteForget about Kevlar lines on main canopies. You cannot trust them for more than 40 jumps. Sure, a few reserves (i.e. Strong 425) were built with Kevlar lines, but have you noticed that we retire them after 20 deployments? You would be far wiser to re-line your PD-280 with 800 pound Spectra suspension lines. Thanks both of you for the advice. I am about to do a reline on this one, and I am starting from zero knowledge about the type. It turned out in the end that I can reline it with 525 Vectran (which I assume was the original line type), or if I wanted to - spectra. I chose Vectran in the end, basically because the canopy won't see many more jumps in its lifetime, and obviously it was a little cheaper. Quote Share this post Link to post Share on other sites
