peterpan
Zero-P or F111
28" ZP = good. If you go bigger than 28", go F-111. I use a 28" ZP and a 32" F-111 (on skydives). I went 32" to get more surface area out there (less burble issue), but F-111 to have less snatch force.
You can really use just about anything, just deploy according to your gear. A standard length bridle and smaller PC work just fine, so long as you burn off your forward speed and keep your wings closed after deployment. On my 32" PC, I use a 10' bridle and the BASE PC pouch, and I pitch it in full flight. If I did this with my "smaller" PC and bridle, I'd more than likely get a hesitation (I've had a PC in tow because of this).
"¯"`-._.-¯) ManBird (¯-._.-´"¯"
Click
