Aviatrr
Pro-track speeds
Anybody know what speed the Pro Track assumes you've deployed when in any mode other than SLO? How about when in SLO mode? I'm sure it says it in the manual....but I have no idea where my manual for the thing is. I had two jumps this past weekend where the pro-track shut down thinking I had deployed less than 30 seconds after exit. I'm assuming I went below the speed at which it thinks you've deployed.
Any problem like this with the Neptune? I'm thinking about getting one for the logging(more than 119sec) and the fact that you can download the profiles with simply an IR port(which I have on my laptop). I could either spend $100 on the Jump Track setup or $250 on the Neptune....trying to decide which.
Mike
that speed is not mentioned in the manula. they say that deployment altitude is when
your decent is slowed down considerably, that's as far as they go in explanation.
stan.
it's not about defying gravity; it's how hard you can abuse it. speed skydiving it is ...
Speed Skydiving Forum
some PCs have IR ports, but the question is would they understand the protocol. you need software that
would work with that device using IR port or RS-232 port.
Yes, you can add an IR port to any PC. They have different versions - cards that insert in the expansion slots of a PC, cards that fit into the PCMCIA slots on notebooks, units that attach to serial ports, USB ports, etc... They're usually kinda hard to find at computer stores - but can be ordered online at many places for about $25-40. My notebook has one built in.
Mike
what i read was that the neptune software would only be compatible with win xp
Odd. Where did you read this? I will NOT use XP, and am running beta software right now, under W2000.
It's your life, live it!
Karma
RB#684 "Corcho", ASK#60, Muff#3520, NCB#398, NHDZ#4, C-33989, DG#1
