ruthers 0 #1 May 17, 2011 I've heard about and seen photos of russian CRW team members with their brake handles stowed on the shoulders, next to the 3 ring releases. Presumably because this allows the jumper to have brakes in hand immediately after pitching and before the risers come up. does anyone know how the brake stows are set up? Is there something on the riser to hook a stow loop on, or is the stow function at the shoulders? Quote Share this post Link to post Share on other sites
Hellis 0 #2 May 17, 2011 Could it be risers from one of these rigs? http://www.flyyourbody.com/en/online-shop/base-jump/base-jump-rig.html Quote Share this post Link to post Share on other sites
CaTo 0 #3 May 17, 2011 QuoteI've heard about and seen photos of russian CRW team members with their brake handles stowed on the shoulders, next to the 3 ring releases. Presumably because this allows the jumper to have brakes in hand immediately after pitching and before the risers come up. does anyone know how the brake stows are set up? Is there something on the riser to hook a stow loop on, or is the stow function at the shoulders? we (CF CaTo) use this concept also with our CF-Storms, and it works. The toggles are clicked on two press-studs on the main-lift cover (?not sure if this is official name). The setup is such that the steeringlines are in half-brake. So no brake-stows needed. After opening (pull-out) we immediatly go for the toggles and are able to steer and correct the opening canopy as needed. If we miss grabbing the toggles, the force on the press-studs during opening is too high to keep, so they will release. (most important rule: if you miss one, let go of the other :-) The smaller the canopy (and higher wingload) the more violent a bad opening can be, and this setup really helps to prevent that (we can correct a beginning twist or 180 during opening)Caren Quote Share this post Link to post Share on other sites
CaTo 0 #4 May 18, 2011 picture of the setupCaren Quote Share this post Link to post Share on other sites
ruthers 0 #6 June 1, 2011 thanks for the info. Quote Share this post Link to post Share on other sites
Divalent 155 #7 June 1, 2011 dang, from the expression on the faces of everyone in the photo, you'd think something really bad just happened. (Like, their jump plane just crashed.) Quote Share this post Link to post Share on other sites
rpersi 0 #8 June 1, 2011 Quotedang, from the expression on the faces of everyone in the photo, you'd think something really bad just happened. (Like, their jump plane just crashed.) ...or the bar just announced they ran out of vodka! Quote Share this post Link to post Share on other sites
JohnnyMarko 1 #9 June 2, 2011 Quotedang, from the expression on the faces of everyone in the photo, you'd think something really bad just happened. (Like, their jump plane just crashed.) "We no smile until jump be success" Quote Share this post Link to post Share on other sites
GLIDEANGLE 1 #10 June 2, 2011 How does this arrangement affect cutting away the canopy?The choices we make have consequences, for us & for others! Quote Share this post Link to post Share on other sites
ScoobieDoo 0 #11 June 3, 2011 according to cato post 3/10, the brakes release if you don't get to them before opening shock. They use these to release brakes and steer their opening canopy to perfect on heading. The question would really be what kind of mal is it? Bag lock prob. won't release brakes? would line twist, meaning you missed releasing both brakes before canopy line twisted. Would these(prob but gonna ask) brakes system release on a baglock cut-away (meaning they didn't release during the baglock and I just pulled silver)? I know some crewdogs still use bags and not tail pockets so thats the question I have. Quote Share this post Link to post Share on other sites
faulknerwn 38 #12 June 3, 2011 I truly suspect that anyone hard core enough to be putting their brakes on their main lift web wouldn't be using a bag on their canopy :-) Its a very rare competitor who uses a dbag.. Quote Share this post Link to post Share on other sites
CaTo 0 #13 June 5, 2011 completely right: we do not use a bag, but a tail pocket, so no worries about bag-locks Caren Quote Share this post Link to post Share on other sites
Zymurdoo 0 #14 June 5, 2011 D Bags are for suckers Blue Skies, Soft Docks and Happy Landings! CWR #23 (It's called CRW, add an e if you like, but I ain't calling it CFS. FU FAI!) Quote Share this post Link to post Share on other sites
CaTo 0 #15 June 5, 2011 and to see it in action: http://www.youtube.com/watch?v=4GWnraTSyqA short clip made using our belly-camCaren Quote Share this post Link to post Share on other sites
