QuoteAirlocks have zip to do with riser pressure or toggle pressure. Those are all functions of the airfoil, the planform, the trim, the AOI and the angle of attack.
True.. true.. but the point I was getting at was that perhaps a rigid parachute will be more resistant to the type of deformation that toggles and risers apply. Perhaps it is not a major factor, but I'm sure it will be some factor.. but perhaps not as much so as the others. Obviously a perfectly rigid wing will respond differently than one that has elastic/plastic behavior.. but I think you still answered my question.
I think, ceteris paribus, that an airlocked wing should have a higher riser and toggle pressure. A rigid wing should be more resistant to deformation.. right? On the other hand, if the wing could deform without causing internal pressure changes (not taking into account the pressure changes due to AOA, etc), then the riser pressure shouldn't be affected by airlocks.
But I will take your word for it ..
riggerrob 644
Several years ago, Brian Germaine told me about an air-locked CReW canopy that he was experimenting with.
It had airlocks near the leading edge, like all the production air-locked canopies.
The problem Brian encountered was that the air-locked canopy was too rigid. Every time he tried to dock, he just bounced off the other jumper.
Brian said that his next CReW canopy would have air-locks back near the B lines, to "soften" the nose.
I've only got about 400 jumps on 5 different Airlocked canopies... but you could cut the airlocks out and it would fly the same. (minus the nice rigid wing over your head
And tomorrow is a mystery
Parachutemanuals.com
