CTSkydiver 0 #1 March 13, 2016 Looking to spend some of my winter earnings on (what for me will be) a couple of significant camera upgrades. Understand these cameras are just now coming to market but looking for any info from others who have used the preceding Sony models to which these are upgrades; specifically with regard to remote tongue switch adapters (I have Conceptus tongue switch currently for Canon) for the mirrorless and HypeEye/CamEye compatibility/limitations/workarounds for the Handycam. All comments / suggestions appreciated. Thanks! Quote Share this post Link to post Share on other sites
degeneration 5 #2 March 14, 2016 Presuming the A6300 uses the same multi-terminal control port as the A5100, A6000 etc, to use your Conceptus tongue switch you'll need a 2.5mm to multi-terminal conversion adaptor. Such adaptors are available from various shops online, one of which is from me (www.skyswitches.com) - it comes with a right angled connector on the sony multi-terminal connector, for £16 + shipping. Other brands are available, and I'm sure the likes of Chutingstar stock some from others.Sky Switches - Affordable stills camera tongue switches and conversion adaptors, supporting various brands of camera (Canon, Sony, Nikon, Panasonic). Quote Share this post Link to post Share on other sites
Pobrause 6 #3 March 15, 2016 Though I have no solution for a work around technique to compensate a hypeeye for the AX33/53 to have a status indication during freefall I've seen some guys using a little piece of plastic that clips the viewfinder in place (pulled out) to make sure the cam is running and then work with the sound of the cam itself for recording indication. With helmet on and earplugs in, turbine running it does proof difficult to hear it, though It's not world changing but it makes things a little easier. ------------------------------------------------------- To absent friends Quote Share this post Link to post Share on other sites
CTSkydiver 0 #4 March 22, 2016 Anyone have quick-release recommendations for these two cameras? Thanks! Quote Share this post Link to post Share on other sites
jtiflyer 0 #5 March 23, 2016 really right stuff quick release with a mount from amazon, great results Quote Share this post Link to post Share on other sites
HighTeckRedNeck 0 #7 April 12, 2016 Have a look at the thread I just posted to convert your bite switch to multi. Quote Share this post Link to post Share on other sites
CTSkydiver 0 #8 April 12, 2016 HighTeckRedNeckHave a look at the thread I just posted to convert your bite switch to multi. Will do. Thanks. Quote Share this post Link to post Share on other sites
jumpsalot-2 3 #9 April 12, 2016 How is the field of view on the AX-53 ? Will it match a 16mm without a wide lens attached ? Will it still auto focus if a wide angle lens is attached ? Can you still get the awesome depth of field with a wide angle lens attached ? Is it working out for skydiving vids ?Life is short ... jump often. Quote Share this post Link to post Share on other sites
CTSkydiver 0 #10 April 12, 2016 jumpsalot-2How is the field of view on the AX-53 ? Will it match a 16mm without a wide lens attached ? Will it still auto focus if a wide angle lens is attached ? Can you still get the awesome depth of field with a wide angle lens attached ? Is it working out for skydiving vids ? Those are all good questions I can't answer yet, as I haven't purchased (or jumped) the cameras yet. I'd love to know the answers, too! According to published specs, the AX-53 has a 35mm equivalent field of view of 26.8 mm in 16:9 4K mode (at widest zoom setting). The 16mm pancake when used with an APC sized sensor like the A6300 has a 35mm equivalent field of view of 24 mm. Seems a good enough fit for me. Quote Share this post Link to post Share on other sites
jumpsalot-2 3 #11 April 12, 2016 Thanks for your reply. I have 1000+ tandem vids with my CX110. I might take it with me to Best Buy and see if I can find a running AX-53 to compare FOV.Life is short ... jump often. Quote Share this post Link to post Share on other sites
jumpsalot-2 3 #12 April 12, 2016 Better idea ...... I have my A6000 and a spare 16mm pancake. I'll take that to compare FOV ...... duh .... Life is short ... jump often. Quote Share this post Link to post Share on other sites
