DBCOOPER 5 #1 February 3, 2015 Just got it. Did a search and didn't come up with any results. Could someone point me in the right direction?Replying to: Re: Stall On Jump Run Emergency Procedure? by billvon If the plane is unrecoverable then exiting is a very very good idea. Quote Share this post Link to post Share on other sites
Dokeman 0 #2 February 3, 2015 Did you read the manual? Quote Share this post Link to post Share on other sites
DBCOOPER 5 #3 February 4, 2015 Perhaps I should have been more specific in my request so even an asshole skygod could understand what I was looking for some help with. Got a new GoPro 3+ that I have never jumped with. I could use some help with the settings that work well in freefall. Taking it to a boogie this weekend and don't have a lot of time to experiment with it nor the equipment with to review the footage prior to returning home 10 days later. But thanks for the input, you have been most helpful.Replying to: Re: Stall On Jump Run Emergency Procedure? by billvon If the plane is unrecoverable then exiting is a very very good idea. Quote Share this post Link to post Share on other sites
daffes 4 #4 February 4, 2015 Do a firmware update, 1080 wide 60 fps, I suggest you avoid super view. For Freefly keep it mostly vertical, for belly, angle it backwards a little bit. Quote Share this post Link to post Share on other sites
DivingWombat 0 #5 February 4, 2015 daffes Do a firmware update, 1080 wide 60 fps, I suggest you avoid super view. For Freefly keep it mostly vertical, for belly, angle it backwards a little bit. Fully agree! Quote Share this post Link to post Share on other sites
Hellis 0 #6 February 4, 2015 ProTune on if it's dark in my opinion. Some might say always on, but I don't think it makes much difference in normal daylight. Quote Share this post Link to post Share on other sites
grantunderland 0 #7 February 4, 2015 I keep it on more to keep the other files from being written than anything else. I have no desire to clutter up my card with a shitty res copy and a thumbnail pic Quote Share this post Link to post Share on other sites
Hellis 0 #8 February 4, 2015 grantunderland I keep it on more to keep the other files from being written than anything else. I have no desire to clutter up my card with a shitty res copy and a thumbnail pic I have a .bat file that deletes the .thm and .lrv files. But I also built a "device" that can do the job when I'm not near a computer. I just plug in the SDcard and push a button and it deletes the correct files. It's annoying that you can't disable those files. Quote Share this post Link to post Share on other sites
Brutus 1 #9 February 4, 2015 I do not think you should record at 60fps if then you are going to edit the video and render it at 30 fps. Depending of the software you are using you could have ending with some annoying ghost effects Quote Share this post Link to post Share on other sites
Hellis 0 #10 February 4, 2015 Never seen that happen because of 60->30 conversion but it has happened because of wrong other settings. What videoedit software do you use? Quote Share this post Link to post Share on other sites
dthames 0 #11 February 4, 2015 daffes Do a firmware update, 1080 wide 60 fps, I suggest you avoid super view. For Freefly keep it mostly vertical, for belly, angle it backwards a little bit. I have noticed that many Windows PCs have a hard time playing back the 60 fps files, smoothly. I run mine at 30 fps and have much better playback results.Instructor quote, “What's weird is that you're older than my dad!” Quote Share this post Link to post Share on other sites
Brutus 1 #12 February 4, 2015 With Sonyvegas I had some issues but I found what to do to get rid of them (thnks youtube tutorial) Quote Share this post Link to post Share on other sites
Remster 30 #13 February 9, 2015 http://gethypoxic.com/blogs/technical/16491013-setting-up-the-gopro-hd-hero3-black-for-skydivingRemster Quote Share this post Link to post Share on other sites
Zlew 0 #14 February 10, 2015 Dont know of others who use these settings, but last season I shot 1080-30 wide video, with a photo every 5 seconds. Worked well and gave me some cool 12MP pics to go with it. Quote Share this post Link to post Share on other sites
