sunnyape 1 #1 November 25, 2014 If you'd like to have an LED on your ringsight to know if your GoPro, ActionCam or similar is recording, here is a simple LED repeater you can make. The completed unit is about 4x5cm, so fits nicely in the space for a Dytter or similar. Depending on how bright the rec light is on the camera, you may need to turn up the sensitivity using the variable resistor and mate / cover the LDR well to prevent external light leaking in. I've used this on a GoPro 2 and GoPro 3, ActionCam AS30 and AZ1. Quote Share this post Link to post Share on other sites
nigel99 681 #2 November 25, 2014 Have you tried using a light pipe? I considered trying it, but stopped jumping a gopro. Another really simple option that a friend has is a tiny dental mirror glued to his alti. Nice thing about your circuit is you can up the brightness...Experienced jumper - someone who has made mistakes more often than I have and lived. Quote Share this post Link to post Share on other sites
linestretch 0 #3 November 25, 2014 I made one similar 14 years ago for my PC1 and it worked great. It ran off a 9v battery and the battery lasted years. If you could, on your diagram give a symbol key to what the different symbols are put them in laymen's terms....and where you buy them. I don't think radio shack would sell all of those parts.my pics & stuff! Quote Share this post Link to post Share on other sites
sunnyape 1 #4 November 25, 2014 This Wikipedia article will provide you with an introduction to electronic symbols: http://en.wikipedia.org/wiki/Electronic_symbol Quote Share this post Link to post Share on other sites
Rover 11 #5 November 26, 2014 http://en.wikipedia.org/wiki/Electronic_symbol2 wrongs don't make a right - but 3 lefts do. Quote Share this post Link to post Share on other sites
billvon 3,169 #6 November 26, 2014 LDR is a CdS light sensor. However most light sensors will work. RS Catalog #: 2760326 is an example. Q1 is an NPN transistor. A 2N2222 would be traditional here, but again almost any will work. Choose a physically small one. VR1 is a 10K potentiometer. D1 is an LED. Almost any will work. Do not use blue or white if you are going the 3V battery route. R1 is a resistor. A 1/4 or 1/8 watt should work fine. Quote Share this post Link to post Share on other sites
peek 21 #7 November 28, 2014 sunnyapeIf you'd like to have an LED on your ringsight to know if your GoPro, ActionCam or similar is recording, here is a simple LED repeater you can make. Here is another one that I designed many years ago: http://www.pcprg.com/camlight.htm Quote Share this post Link to post Share on other sites
