SPAWNmaster 0 #1 March 17, 2014 Hi there, updating my RAWA to be more modern and safe. Just removed side box (in favor of top-mount and no longer using old side-mounted DV cam). Now I would like to remove the ladder strap on one side to set up a cutaway system and seeking advice. Attached is the picture, looks like the strap is held on via rivet? Or some sort of snap? Should I just drill through from the outside or try and break the rivet-looking piece inside and then pry washer-looking part off? Thanks, Quote Share this post Link to post Share on other sites
normiss 915 #2 March 18, 2014 You'll have better luck drilling the side that the rivet is squenched on. The inside. Might need a 90 degree drill head or geared adapter to get in there. Speaking of which....I still need to fill the slot for the cable for the old camera box on mine! Quote Share this post Link to post Share on other sites
SPAWNmaster 0 #3 March 18, 2014 Thanks, 90 deg bit is worth a shot! Quote Share this post Link to post Share on other sites
normiss 915 #4 March 18, 2014 I picked up a 90 degree geared head that fits on any drill. Cheap too! Quote Share this post Link to post Share on other sites
SPAWNmaster 0 #5 March 26, 2014 I ended up drilling from three different angles with a straight bit. Finally the washer gave and then the rivet was easy to finagle out. Quote Share this post Link to post Share on other sites
normiss 915 #6 March 26, 2014 I find cussing helps. Quote Share this post Link to post Share on other sites
hcsvader 1 #7 April 2, 2014 how did you remove the camera box? I had to replace the ladder strap on mine and I just drilled it out and replaced it with a bolt.Have you seen my pants? it"s a rough life, Livin' the dream >:) Quote Share this post Link to post Share on other sites
SPAWNmaster 0 #8 April 2, 2014 Quotehow did you remove the camera box? Box was fairly easy. Peel away the foam in the box, used pliers to break the plastic rivet pins then drilled through the remaining pieces of the pins and washer. Very soft material (aluminum+plastic?). Quote Share this post Link to post Share on other sites
SPAWNmaster 0 #9 April 2, 2014 Figured I'd share the final product here in case anyone was curious. Quote Share this post Link to post Share on other sites
