WMO 0 #1 May 23, 2013 How can I improve rendering speed with Vegas Platinum? Quote Share this post Link to post Share on other sites
bodypilot90 0 #2 May 23, 2013 are you on a desk top or lap top,? Quote Share this post Link to post Share on other sites
DSE 5 #4 May 25, 2013 from what format are you rendering? Two what format are you rendering? What are your project settings? Quote Share this post Link to post Share on other sites
kallend 2,215 #5 May 30, 2013 Well, since the OP hasn't responded, are there any general tips? Does the output format matter much? Frame rate? Input format? Number of effects applied?... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
DSE 5 #6 May 30, 2013 any time the output departs from the input, it will have an affect on render times. For example, if you shoot 108p60 AVC with your GoPro, and want to output 720p24 for the web, it'll add some render time because each frame has to be resampled. If you pile on a lot of effects, then that too, slows things down because not only does each frame need resampling, but also needs to have the effects processed. If you scale bigger than original, that takes time. If you shoot for output, ie; shoot 720p30 for 720p30 output, that'll give the fastest render. Quote Share this post Link to post Share on other sites
WMO 0 #7 May 31, 2013 Currently shooting GoPro 720-60. Previously shooting CX 100 standard def. Any tips on setting up the input output settings,Quote Quote Share this post Link to post Share on other sites WMO 0 #8 May 31, 2013 Rendering to DVD, without going through DVD Architect. Quote Share this post Link to post Share on other sites DSE 5 #9 May 31, 2013 p60 and HD are going to be very slow by comparison to SD rendering to DVD. Rendering from HD to SD is slow, rendering from GoPro's non standardized format to standardized SD will be slow. GoPro isn't a good source for speedy video render in the best of scenarios; you've unfortunately created one of the worst scenarios. Faster computer with an accelerated graphics card will help. Quote Share this post Link to post Share on other sites WMO 0 #10 June 1, 2013 Shooting GoPro 720-60 widescreen, project properties frame rate doesn't have a 60 fps option, set on 29.970 NTSC. Rendering quality set to Good. Quote Share this post Link to post Share on other sites Hellis 0 #11 June 1, 2013 Just change it to 60 manually. Quote Share this post Link to post Share on other sites DSE 5 #12 June 1, 2013 HellisJust change it to 60 manually. This. In the project properties, those fields can be changed. Then save as a Project Properties Preset if you'd like. Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
