DSE 5 #1 April 22, 2013 Hey gang, a few DZ's are now restricting the use of cameras to only helmets that have a cutaway system (including full-face helmets). I've rec'd a few PM's asking about cutaway systems, and there are indeed a few aftermarket cutaway systems available. If you manufacture a cutaway system, know of a person/company who does, or have a self-developed system worth sharing, this is the thread in which to do it. Posts debating the value of a cutaway system will be deleted. Posts about who should/shouldn't be flying with small format/POV cameras will be deleted. This thread is intended as a research resource for those searching for cutaway information. Quote Share this post Link to post Share on other sites
Divalent 155 #2 April 22, 2013 Here is a retro fit cutaway system for open face helmets by Parasport Italia: http://www.gravitygear.com/store/product166.html Quote Share this post Link to post Share on other sites
adamUK 3 #3 April 23, 2013 2k composites do a retrofit cutaway system but not US-based unfortunately. http://www.2kcomposites.co.uk/2kc-button-cutaway-7-p.asp Quote Share this post Link to post Share on other sites
DSE 5 #4 May 6, 2013 http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=4481439#4481439 Quote Share this post Link to post Share on other sites
gearless_chris 1 #5 May 6, 2013 Looks like they use a different cutaway set-up now. I have a 2k Composites chincup cutaway on my Bonehead Mindwarp helmet. It looks a lot like the Cookie system."If it wasn't easy stupid people couldn't do it", Duane. My momma said I could be anything I wanted when I grew up, so I became an a$$hole. Quote Share this post Link to post Share on other sites
jono 0 #6 May 7, 2013 Quote 2k composites do a retrofit cutaway system but not US-based unfortunately. http://www.2kcomposites.co.uk/2kc-button-cutaway-7-p.asp Yep, got the 2k cutaway on my open face and fitted it to the chin strap. Have not had to use it in anger as yet but have tested it under load and it worked perfectly. Yes you will loose the pin if you have to cutaway but figure it's a small price/hassel to pay for keeping your head attached. It's simple with no protruding parts on the inside to poke your face and took me about 5 mins to unbolt the chin strap on one side and fit the spring loaded pin in and thread the cable. I also fitted some extra velcro for the ear pad. I lube the cable at the same time I do my monthly maintenance on my rig. Doesn't matter shit if they are not US based. They post anywhere.Remember you don't stop laughing because you grow old, you grow old because you stop laughing. Quote Share this post Link to post Share on other sites
guscabana 0 #7 June 17, 2013 Hi All, after 22 years jumping camera helmets without cutaways, Im starting to think about installing them (maybe is the age, also I installed skyhooks in all my rigs ;-) What about the retrofit hinge for the Flat Top pro? http://www.boneheadcomposites.com/m8/656--flat-top-cutaway-hinge-retrofit.html Someone used it in an actual jump? works smoothly? Thanks! Quote Share this post Link to post Share on other sites
skykatherine 0 #8 September 9, 2013 What do y'all think of Brian's version of a cutaway system?? http://youtu.be/WuqJV3eRH0g Quote Share this post Link to post Share on other sites
shibu 1 #9 November 6, 2014 I saw a cutaway system for the cookie fuel but none for the G3. What are the current cutaway options for the G3? Quote Share this post Link to post Share on other sites
Wjtyrer 1 #10 March 14, 2015 https://www.youtube.com/watch?v=WuqJV3eRH0g Brian Germain has a cool method for making G3 cutawayBlue skies Quote Share this post Link to post Share on other sites
rwcskydiver 0 #11 May 29, 2016 New camera mount cutaway for the G3 with gopro. Cuts the camera mount away, helmet stays on. www.collettetech.com Quote Share this post Link to post Share on other sites
OzzieDave 1 #12 August 1, 2016 A non destructive G3 cutaway solution (no holes, no damage, completely reversible) that completely removes the tensioned line that runs around the back of the head allowing the helmet to come off wit ~2kg of static force http://www.overdoseindustries.com/ad Quote Share this post Link to post Share on other sites
