Peterkn 17
QuoteIf the seatbelts are off and the door is open on an Otter, then a pilot chute getting out the door is likely to be a problem for one person. I think by 1000ft the risk of it happening vs the odds that it can be handled by a jumper are reasonable. I'm familiar with the WFFC incident a few years back where the premature deployed into the horizontal stabilizer, but that guy climbed out and held on all the way to inflation which wouldn't happen in the case we're talking about.
If the seatbelts are on and the door is open a pilot chute getting out the door is likely to be a problem for the whole plane whether you're at 1000ft or not. The risk of it happening isn't really any greater than in the above case but the stakes are much much higher.
I disagree.
If a pilot chute goes out the door then the jumper connected to it is going to manufacture a new door opening, somewhere between the trailing edge of the existing door and the tail of the aircraft.
Not only will this severely compromise the structural integrity of the aircraft but it’s very likely that the control mechanisms will also be damaged in the process – not great for anyone still in the aircraft, especially the poor pilot.
Don’t be fooled into thinking that the jumper will be able to respond quickly enough by diving out of the door after their pilot chute – if they were that switched-on then they wouldn’t have gotten themselves into this situation in the first place.
Hopefully we’ll never get see which one of us is right about this.
Pete.
Quotefeel free to send all the pa's you want buddy
And what would that be?
Sparky
QuoteStructurally speaking, the door on Cessna's is a must. Something ridged needs to be there for airframe flex.
Then how come the FAA says the following aircraft can be operated with door off? See attachment.
Sparky
pchapman 280
Ever taxied a C-182 etc on grass with the swing up skydiving door ajar? There's a surprising amount of flexing movement of the airframe around the door. At one DZ the rule (not always observed) was to taxi with the door closed, and I can understand why.
I don't know how tightly the door fits, but at some point it will take some of the loads, stiffening that giant hole in the structure. It's mostly the fuselage twisting sort of loads that cause the distortion, typical in ground maneuvering on uneven surfaces.
So it is "OK" to have the door open or off. But the plane isn't quite the same without.
QuoteSo it is "OK" to have the door open or off. But the plane isn't quite the same without.
I agree with you completely. I was responding to Tiddy’s comment “the door on Cessna's is a must”. When I started jumping everything was flown without a door. But a lot of things have changed since then most for the better.
Sparky
Driving is a one dimensional activity - a monkey can do it - being proud of your driving abilities is like being proud of being able to put on pants
