Scrumpot 1
QuoteIf you are too dainty, delicate, prissy, sissified, etc. to sweat for an extra minute, then you are too dainty to skydive with me!
That's right peeps... HARDEN THE FUCK UP!
Remster 30
If we can have the door closed in the f'ing Eloy heat in summer from take off till 1,500 feet, all you pussies in the rest of the world can.
rwa2468 0
www.htfu.com
Tiddy 0
If the aircraft was designed without a door and has no door, than by all means, knock yourself, but if the door was removed, (any Cessna for example) I would wave'em off...
Structurally speaking, the door on Cessna's is a must. Something ridged needs to be there for airframe flex.
As far as the door popping open on take off, the dz/pilot needs to brief the procedure. I know at the DZ that I fly/jump at, I have told them that I will get around to closing the door in a timely manner. If it pops open just as you leave the ground, the last thing I need is someone in the door trying to close it. With an aft door, before anyone does anything, they should know what they are doing.
Door pops open, hand on your pilot chute, look for instruction....
I definitely agree with a PP that I too despise/fear the partial cracking of the door on take-off- either open it or close it damn it, either allow enough room for the whole skydiver to follow the PC out if necessary, or prevent it in the first place!
At my home dz, on really hot days, they'll ask for it open right after seatbelts come off (1k)... especially if I am right near the door, I am guarding my hackey like there is no tomorrow and pretty much holding my breath and checking my alti- "okay 1100k, emergency exit go to reserve and pray I don't die... 1600, reserve and pray... 2500 okay finally okay with the main as the first shot..." and then around 3.5-4 k normal pull altitude for my main, I can breathe again, lol.
But it is fully open as opposed to partial in such situations at my home dz, so I do feel better about that- I just get anxious between 1k and my normal pull alti. I'm a nervous newbie, but yes I would rather suffer through a few more minutes of heat and wait an extra 1k feet or so after seatbelts off to open the door..
And at least it is not generally open before the seatbelts come off as the original post referenced! That is scary stuff!
Thanks for posting-- Totally valid points about needing to keep the door shut AT LEAST until seatbelts are off, perhaps a bit later, and also about leaving it either fully open or fully closed at any point.. hope all other dZs take heed! Could go very very badly if not...
blues,
R
QuoteStructurally speaking, the door on Cessna's is a must. Something ridged needs to be there for airframe flex.
Really? That explains all the Cessna 172, 180, 182, 185, 195's I see around with broken door jams & wing mounts, after all of those years flying around without door has caused all that damage......
bigbearfng 18
QuoteYeah... I don't think I have had many experiences with door open fully from take-off, but traveling and jumping I think there have been occasional instances where the door is propped open maybe 12 inches or so on take-off..
blues,
R
Very good to see you paying attention like that-
A little additional food for thought for you-
Any hills around the DZ that the aircraft climbs over? Then that 1000ft/1600ft etc. just became a lot less.......
Also consider any hills for your planned breakoff and pull altitudes-good example of this is in San Diego.
peek 21
QuoteAt my home dz, on really hot days, they'll ask for it [the door] open right after seatbelts come off (1k)... especially if I am right near the door, I am guarding my hackey like there is no tomorrow ...
I wish more people would be this careful. I often see people moving around, seemingly oblivious as to where their pilot chute handle is, just as soon as their seatbelt is off.
I think a lot of people assume that everything on their gear will stay put regardless of movement.
If my pilot chute handle is right by an open door, I have been known to hold onto to it until everyone in the vicinity gets situated and stops moving around.
riggerrob 644
QuoteQuoteStructurally speaking, the door on Cessna's is a must. Something ridged needs to be there for airframe flex.
Really? That explains all the Cessna 172, 180, 182, 185, 195's I see around with broken door jams & wing mounts, after all of those years flying around without door has caused all that damage......No wonder they crash!
Doors are rarely "structural components" in non-pressurized airplanes.
Doors only become structural components in pressurized (e.g. Beechcraft King Air) airplanes and large transports.
Hint: look at the number of latches and try to see if they are connected to warning lights in the cockpit.
Cessna tested most of their single-engined airplanes (120, 140, 150, 152, 170, 172 175, 180, 182, 185, 205, 206, 207, 208) "for flight with a door removed" in order to make it easier to sell them to skydiving schools.
Even so, most pressurized airplanes still have to prove that they can maintain controlled flight - with a critical door open (e.g. nose baggage door on Cessna 400 series twins) - before they can get a Type Certificate.
JackC1 0
Litterally at 45 degrees straight after take off. Fuck that.
Jumped an Arava with open doors, no seat belts and a slick floor years ago...YAHOOOO!
Fuck THAT is right!
QuoteLitterally at 45 degrees straight after take off. Fuck that.
Fuck THAT is right!
You talking about that one that was at Elsinore back in the 70's?
SparkyMy idea of a fair fight is clubbing baby seals
QuoteQuoteLitterally at 45 degrees straight after take off. Fuck that.
Fuck THAT is right!
Sparky
That one and the newer one that was in Sandyeggo in the 80's...I also jumped a newly configured DC-3 turbine once. I bet my fingernail gouges from sliding around during take-off are still in the floor!
CMiller 1
Gato 0
We're currently making use of a U206 with a right-side cargo door. The door itself is a roll-up cordura and vinyl panel that velcros to the sides and floor.
The first few times I had to take the door position, it didn't bother me at all, because it was colder at the beginning of the season. When it got warm, and people asked me to open the door at 1k, I was juuuust a bit hesitant. No one had to tell me, "Make sure your seatbelt is off!!" - if things go to shit, you can be assured I will NOT be in your way, and if I am, MOVE ME. Anyway, I'm still not willing to roll it all the way up. I'll check my handles, and then roll it up to about a foot off the floor, resting my left knee against it, and that seems to cool things off just fine.
The partial roll of door also serves as a mighty fine armrest.
One thing about sitting in the door position (if it's open on the way to altitude,) I don't think it's a good idea to do the helmet-on-the-chest strap thing - you pretty much have to be ready to launch out the door from 1000' up. Just my opinion. It does make me wonder if we should do what we make students do: Put everything on, and leave it on. Sorry, getting off topic, now.
One other thing no one's mentioned yet: If the door's open on the way to altitude, you're robbed of the privilege of yelling, "Door!"
NWFlyer 2
I've jumped at 25+ dropzones and I don't think I can ever recall a place where the door was not re-closed at some point prior to jump run; usually between 5,000 and 8,000 feet depending on how hot it is. This allows for everyone to safely do handle checks, for the TIs to safely hook up their students, for people to move around getting in position and putting up benches, without the added risk of something getting bumped during that process with an open door.
So you can still yell "DOOR!"
JohanW 0
But for initial climb and whenever the door is open, I almost always have it on my head. (OK, so I'm not perfect.)
I am. I think.
Yup, out flew the reserve on take off, right onto the floor next to the door.
We were at rotation.
I'm really glad the door was closed. It was summer and hot as hell.
Shut the door. All the way.
