dima39 1 #1 August 4, 2010 My GoPro HD now has problem with USB connection - it's can charge battery, but can't be recognized in computer like USB drive :(. I connected it with different cables to different computers - same problem, without results. Any suggestions? P.S. I'm living in Russia, so send it in US for repair - very long end expensive solution. Quote Share this post Link to post Share on other sites
4dbill 0 #2 August 4, 2010 I have never used my USB connector that came in the box. Instead, I always use the SD card reader. Has anyone used the Wi-Fi SD card yet? 4DBill Quote Share this post Link to post Share on other sites
BobWright 0 #3 August 5, 2010 Mine sometimes does that- if you plug it into a USB port the red charging indicator comes on but I can't get it into USB transfer mode. However, in the past when that has happened, I just left it in the charging mode until it was done charging (red light off). When I reconnected it after that, the USB connection worked again. I just assumed it meant that the battery was low enough that the USB transfer couldn't work. Quote Share this post Link to post Share on other sites
Sangi 0 #4 August 5, 2010 If you connect it via USB while the camera is off there won't be any file transfer connection, only the charging of the battery.. However if you turn on the camera and then plug in the USB there will be a normal file transfer connection regardless if the battery is half charged or low or whatever.."Dream as you'll live forever, live as you'll die today." James Dean Quote Share this post Link to post Share on other sites
dima39 1 #5 August 5, 2010 Quote However if you turn on the camera and then plug in the USB there will be a normal file transfer connection regardless if the battery is half charged or low or whatever.. It worked before for files transfer - doesn't work now (no USB symbol on display)... It's filming, playing on TV, charging - but can't transfer files to computer. May be connectors on main-board inside camera damaged during connecting/disconnecting USB cable ??? But why it's charging normally with same USB cable ?? Quote Share this post Link to post Share on other sites
castle_bravo 0 #6 August 5, 2010 Could be a damaged memory card. Have you tried a different memory card in your GoPro? Also, have you tried reading your current memory card in some card reader ? Quote Share this post Link to post Share on other sites
tunnelfly 0 #7 August 6, 2010 Quote May be connectors on main-board inside camera damaged during connecting/disconnecting USB cable ??? But why it's charging normally with same USB cable ?? The camera is charged trough the 5V wires (pins 1 and 4), while the data is transfered through the bus wires (pins 2 and 3). No.1 reason NOT to be an astronaut: ...You can't drink beer at zero gravity... Quote Share this post Link to post Share on other sites
howardwhite 6 #8 August 6, 2010 I've found that this usually works: -Plug it into the computer; the red light comes on. -Turn the camera off; then turn it on again. The USB symbol comes on. As noted, if the battery is low/dead, you may have to wait until you have a partial charge. HW Quote Share this post Link to post Share on other sites
elton01 0 #9 August 9, 2010 Yeah, I get the same issue occasionally. All I do is allow it to charge for 5 minutes, (red light on), unplug, then turn the camera ON, then plug the USB cable in, it starts up in windows 7 and recognizes the drive with no issues. If you still can't recognize the drive, then pull the SD card and reformat/reinstall. It might help. Quote Share this post Link to post Share on other sites
wsbigdaddy 0 #10 August 18, 2010 Had same issue for a while For me it was a difference between using a USB cable that plugs into just one USB port, as opposed to one that splits into two Having both those plugged in at the same time seemed to finally make it show up Quote Share this post Link to post Share on other sites
Nukrites 0 #11 January 28, 2011 I still have that problem, windows does not allow file transfer, but on mac system it works, any solution? Is it possible to reinstall gopro firmware or something? Quote Share this post Link to post Share on other sites
bomb420 1 #12 January 30, 2011 With the gopro turned on plug it into the computer. Open up windows explorer and see if a new drive shows up. If not Go to start->control panel->system->Device Manager Right click and select scan for new hardware devices. See if something shows up. Expand "Disk drives" and see if the go pro shows up there. It'll come up as "AMBA Storage USB Device" If no drive letter shows up in windows explorer there is probably another drive letter assigned to the one the drive would like. I've seen this before a few times on different devices. Right click on properties of the mentioned device, and select volume. Select populate. See if a drive letter shows in there. Try manually running that drive letter. Example: 'H' drive. Hit 'Windows key'+'R' type in "h:" and hit run. See if it comes up. If not goto control panel->administrative tools and select computer management. Mine is currently not loading up but I believe it's drive management or something. From there select the volume that does not have a drive letter assigned to it and select properties and give it a drive letter. If it's working on a MAC it means the HID layer is working correctly and its just a matter of something mis-configured on your PC. Hope this helps. Perhaps search online for how to trouble shoot a harddrive/sd card that is not showing up on Windows 7. Blue Ones, TrunkHYPOXIC Quote Share this post Link to post Share on other sites
MrChaos 0 #13 February 20, 2012 I got the same problem with my Gopro HD cam, it charges fine, but can't get into USB mode, and I got another problem, when ever I have charged the cam, I HAVE to pull out the battery and insert it again, else the cam won't turn on, is that normal ? And the SD card is brand new, and I have had it in a SD-card reader, and it works great. So if anyone have a fix to my problems I would be happy Quote Share this post Link to post Share on other sites
trunk 0 #14 February 20, 2012 Sounds like it's over-currenting. I've had a few of those back in the day. Contact gopro via their web site http://gopro.com/support/ and enter in your serial number of your gopro with a description of the problem. Next search for the receipt as you will need that to get it RMA'd.Trunk's Blog HYPOXIC's Instagram Like HYPOXIC Quote Share this post Link to post Share on other sites
