sbb 0 #1 May 1, 2010 DSE or anyone with knowledge to share I have the Vasst training DVD and was looking at the file properties of the templates and production assistant. I see some differences in a few options that I don't fully understand. One template is HDV 1080-60i, other NTSC-DV widescreen. What is the importance, if any, of the following: field order: upper or lower field first pixel format: 8 bit or 32 bit motion blur: gaussian or other? deinterlace: blend vs deinterlace Quote Share this post Link to post Share on other sites
jasonlee55555 0 #2 May 3, 2010 I don't undrstand some of this myself. However, there are a lot of examples of how to adjust your settings and what they look like on youtube. The best place to learn almost anything. Quote Share this post Link to post Share on other sites
DSE 5 #3 May 3, 2010 HD is always UFF (Upper Field First). If it's going to the web, i generally let Vegas manage the deinterlacing. The rule for deinterlacing is this: Hi speed/high motion; deinterlace with Interpolative Low speed/Motion; deinterlace via Blend Skydiving is not high speed/motion in most instances because the camera is relative to the action. Gaussian blur (default) is generally best unless you're animating still frames, then Box is better. HDV 1080 60i means the output shall be 1440 x 1080 @60 half frames (interlaced) per second. NTSC DV means it will be 720 x 480 @60 half frames (interlaced) per second. Make sense? Quote Share this post Link to post Share on other sites
