gilead1 0 #1 November 3, 2009 hello since I have some neck problems the weight of the camera is very important to me as long as the quality is good enough for tandem - any recommendation? (I didn't find any thing about cameras weights in the search) Quote Share this post Link to post Share on other sites
billvon 3,118 #2 November 3, 2009 Depends on the quality you want. The CX100 will take so-so pictures through the lens during video capture; the Hypeye will let you use a shutter release with it. The GoPro will shoot stills continuously with slightly better results. Point and shoot cameras are the next step up. Most point and shoots can be modified for remote shutter release via some soldering. I used a DSC-V1 for a while with good results. The Canon G10 is a good high end point and shoot. It's light and doesn't need a separate wide angle lens (which saves weight) - they run around $500 nowadays. Quote Share this post Link to post Share on other sites
Jonntis 0 #3 November 3, 2009 A few pretty nice pictures taken with ricoh compacts have been posted on this forum. They weigh about 200grams and according to the ones jumping them, the quality works for tandem, at least in good light conditions. They're pretty fast, have a 24 mm wide angle and you can mod the cable switch to work with a mouthswitch. Try search ricoh. I'm not jumping stills. /Jonathan Quote Share this post Link to post Share on other sites
gilead1 0 #4 November 3, 2009 thanks for the quick response, I'm using the cx100 with Hypeye for the video but the stills quality is poor, definitely not enough for tandem, I think the canon g10 is what i'm looking for thank gilead Quote Share this post Link to post Share on other sites
BMFin 0 #5 November 3, 2009 Agreed, a compact such as the G10 definetly has the best image quality/weight ratio. Quote Share this post Link to post Share on other sites
antonija 0 #6 November 4, 2009 Considering G10 is ageing and G11 is out, is G10 still the best choice?I understand the need for conformity. Without a concise set of rules to follow we would probably all have to resort to common sense. -David Thorne Quote Share this post Link to post Share on other sites
PhreeZone 20 #7 November 4, 2009 Yes, the G11 packed too many pixels in the same size sensor and increased the noise on the images a lot more then the G10 had at even medium ISO's.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
BMFin 0 #8 November 4, 2009 QuoteConsidering G10 is ageing and G11 is out, is G10 still the best choice? Personally I dont know much about the differences between the G10 and G11. What phree said could be true.. My point was that a compact such as the g10 is the best choice. Not necessarily exactly that model. If you truly want some High IQ with low weight, you need to look at some other things like the leica X1 (286grams) or the Leica m9 (585grams) But these cameras go far beyond what is reasonable for shooting tandems.. A G10 will do just perfect. Quote Share this post Link to post Share on other sites
Arekas 0 #9 November 10, 2009 QuoteYes, the G11 packed too many pixels in the same size sensor and increased the noise on the images a lot more then the G10 had at even medium ISO's. It is not quite true. Theoretically G11 is better camera than G10 because of smaller pixel density (23 vs 34 MP/cm²) , quicker continuous drive (1.1 vs 0.7 fps ) and HDMI output too. You can compare the cameras specifications there http://www.dpreview.com/reviews/compare_post.asp?method=sidebyside&cameras=canon_g10%2Ccanon_g11&show=all. I suppose G11 is best camera in the class. Quote Share this post Link to post Share on other sites
billvon 3,118 #10 November 10, 2009 >It is not quite true. Theoretically G11 is better camera than G10 because > of smaller pixel density (23 vs 34 MP/cm²) . . . . That's what he said. The pixels are smaller (generally means noisier) and the sensor has more resolution than the lens does, so increasing sensor resolution doesn't really buy you anything. You basically get a larger file representing the same quality image (ignoring the noise issue.) Quote Share this post Link to post Share on other sites
antonija 0 #11 November 10, 2009 Now you really got me confused... Here are relevant stats from the two cameras: G10: Max resolution: 4416 x 3312 Effective pixels: 14.7 million Pixel density: 34 MP/cm² Continuous Drive: 0.7 fp G11: Max resolution: 3648 x 2736 Effective pixels: 10.0 million Pixel density: 23 MP/cm² Continuous Drive: 1.1 fps So.... G11 compared to G10 has less effective pixels, lower resolution of the sensor, lower pixel density and faster continuous drive. To me that spells less noise, better image (because it's not limited by glass, but by sensor) and more shots per second. And G11 is a little tiny bit lighter.I understand the need for conformity. Without a concise set of rules to follow we would probably all have to resort to common sense. -David Thorne Quote Share this post Link to post Share on other sites
Jonntis 0 #12 November 10, 2009 I'm definitely not a stillcamera expert but it looks like people are talking about different cameras here. According to test's I've read but cannot confirm the G11 has far less problems with noise and artefacts than the G10. Maybe they named them different in Europe and US? Quote Share this post Link to post Share on other sites
Arekas 0 #13 November 11, 2009 QuoteSo.... G11 compared to G10 has less effective pixels, lower resolution of the sensor, lower pixel density and faster continuous drive. To me that spells less noise, better image (because it's not limited by glass, but by sensor) and more shots per second. And G11 is a little tiny bit lighter. You are absolutely right . Pre-IFA 2009: Canon has announced a handful of compact cameras including models aimed squarely at keen photographers. Top of the line is the PowerShot G11, successor to its flagship PowerShot G10 compact released last year. The G11 replaces the G10's 14.7MP sensor with what it describes as a high sensitivity 10 MP CCD though it still uses the same 28-140mm equivalent stabilized lens. The camera also gains a tilt and swivel LCD, though the size drops to 2.8 inches. Flash sync speed increases to 1/2000th of a second and HDMI output is also added. Other features include Dual Anti-Noise System (more sensitive sensor and Digic 4 offering a claimed 2-stop improvement over the G10), RAW shooting and P/A/S/M shooting modes. Quote Share this post Link to post Share on other sites
Jonntis 0 #14 November 11, 2009 Ricoh's got a new model coming out in december. Interchangeable camera unit(!). Weighs 325 grams lens included. Looks to me like it has all the features necessary for skydiving and takes 5 RAW frames/second. http://www.ricoh.com/r_dc/gxr http://www.youtube.com/watch?v=gXS820Ut7lA&feature=channel /Jonathan Quote Share this post Link to post Share on other sites
SStewart 13 #15 November 12, 2009 QuoteQuoteConsidering G10 is ageing and G11 is out, is G10 still the best choice? Personally I dont know much about the differences between the G10 and G11. What phree said could be true.. My point was that a compact such as the g10 is the best choice. Not necessarily exactly that model. If you truly want some High IQ with low weight, you need to look at some other things like the leica X1 (286grams) or the Leica m9 (585grams) But these cameras go far beyond what is reasonable for shooting tandems.. I can't tell, can you plug a remote shutter switch into these?Onward and Upward! Quote Share this post Link to post Share on other sites
skyjumpenfool 2 #16 November 12, 2009 Quote I can't tell, can you plug a remote shutter switch into these? The G-10... YES! G11.... I Don't know.Birdshit & Fools Productions "Son, only two things fall from the sky." Quote Share this post Link to post Share on other sites
SStewart 13 #17 November 12, 2009 I was referring to the Leica cameras.Onward and Upward! Quote Share this post Link to post Share on other sites
BMFin 0 #18 November 13, 2009 Quote I can't tell, can you plug a remote shutter switch into these? I cant tell either... Quote Share this post Link to post Share on other sites
strop45 0 #19 November 14, 2009 my understanding is that the short answer is no. I use a lumix LX3 which has a leica lens and have made up a shutter release using a r/c servo and small circuit see http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=3546981;#3546981The difference between stupidity and genius is that genius has its limits." -- Albert Einstein Quote Share this post Link to post Share on other sites
Skydivesg 7 #20 November 14, 2009 Do you mind explaining how all the new changes that are on the G11 makes it better than the G10. I'm not arguing I'm just trying to learn. I'm about to get one of them but I don't know much about them. I don't quite understand all the jargon or complexities yet. Thanks for your help.Be the canopy pilot you want that other guy to be. Quote Share this post Link to post Share on other sites
Arekas 0 #21 November 15, 2009 This may sound strange but main advantage G11 over G10 is reduced number of pixels. 14.7MP is to much for such small sensor and for the lens too. More pixels in the same square means more noise, more noise (even in low ISO) means less sharp images. I think 14.7MP in G10 is marketing trick. Both cameras can capture very close number of details in low ISO but in higher ISO G11 is a winner. Personally i think G11 can capture wider range of colors and bright/black tones. G10 and G11 are grate cameras the difference is only minor. G11 is a little bit faster. HDMI output can be useful too if you plan to present the images to client on HD TV display. Quote Share this post Link to post Share on other sites
