tsalnukt 1 #1 June 28, 2009 After many fruitless searches I am asking for help. I have a cx100 and a mac with FCE. I plug everything in and click on Log and Transfer and the screen comes up but how do I get my footage into the log and transfer screen? I am also having trouble with importing clips from imovie into fce. Any help that anyone can give me would be greatly appreciated.thanks Quote Share this post Link to post Share on other sites
PharmerPhil 0 #2 June 28, 2009 I don't use Final Cut Express, but if it is anything like Final Cut Pro (probably) here's how it works... In the log and transfer window, in the upper left, there is little icon of a folder with a plus (+) sign in it. Clicking this lets you navigate to wherever the files are. Or, simply drag the entire "BDMV" folder into the log and transfer window, and all associated clips will show up there. Quote Share this post Link to post Share on other sites
tsalnukt 1 #3 June 28, 2009 When I do that I get this warning "BDMV" contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media. When I open the "stream" and "playlist" folders just by themselves there is nothing there. When I check the camera all the clips/files on the camera they are all there. Am i missing some settings or steps somewhere? Quote Share this post Link to post Share on other sites
PharmerPhil 0 #4 June 28, 2009 Is it an Intel-processor-based Mac (required for AVCHD)? Are you shooting your CX-100 in HD? What version of FCE are you using? Quote Share this post Link to post Share on other sites
DSE 5 #5 June 28, 2009 First question is which version of FCE are you using. Phil nailed the second part; Is it an Intel-based proc? If not...game over. Then, be sure you're importing entire file structure/folders intact. This is CRITICAL with Apple systems. Quote Share this post Link to post Share on other sites
tsalnukt 1 #6 June 28, 2009 Yes, intel based macbook. I have been shooting in SD mode for tandem videos. Do I have to shoot in HD to get it to work in FCE?? Quote Share this post Link to post Share on other sites
PharmerPhil 0 #7 June 28, 2009 QuoteDo I have to shoot in HD to get it to work in FCE?? I have never imported SD footage from these cams, but the owners' manual says: "Standard definition video recorded with AVCHD camcorders cannot be accessed in the Log and Transfer window." I don't know if there is another way to import SD on this program but I suspect there is. Have you tried just using the "import files" (under the "File" menu) and directing it to the actual files? Quote Share this post Link to post Share on other sites
DSE 5 #8 June 28, 2009 you'll have to convert it first then. StreamClip is a good tool, there are others. The SD content is standard MPEG2 with embedded AC3 audio. Apple just doesn't like MPEG. Quote Share this post Link to post Share on other sites
tsalnukt 1 #9 June 29, 2009 That's it. Must be HD to work. Is there a way to convert the video I shot or so I can edit in FCE4 or should I just do it in imovie? thanks Quote Share this post Link to post Share on other sites
howardwhite 6 #10 June 29, 2009 Toast Titanium 10 has a Convert function which does AVCHD conversion to several formats. It seems to work nicely and reasonably fast. HW Quote Share this post Link to post Share on other sites
DSE 5 #11 June 29, 2009 QuoteThat's it. Must be HD to work. Is there a way to convert the video I shot or so I can edit in FCE4 or should I just do it in imovie? thanks Well...iMovie can edit it after conversion, or you could use the demo of StreamClip or Titanium to convert them. Converting the MPEG2 to IAC or ProRes is no big deal and takes little time. Quote Share this post Link to post Share on other sites
tsalnukt 1 #12 June 29, 2009 This might be silly but how do I use stream clip. I downloaded it, opened it, pluggeed in the camera and I can't seem to get it to really do anything? what am I doing wrong? Quote Share this post Link to post Share on other sites
