velocityphoto 0 #1 May 26, 2009 I Have version 5.0 and am trying to do an hd video but the default setting is 720x480 ntsc in disk properties. The drop down doesn't give anything higher than that? Any suggestions? Thanks A friend will bail you out of jail , a REAL friend will be sitting next to you in the cell slapping your hand saying "DUDE THAT WAS AWSUM " ................ Quote Share this post Link to post Share on other sites
beowulf 1 #2 May 26, 2009 I can't remember exactly what I had to do for it to be set to HD. When I get home I will be able to give you more specifics. Try creating a New Project and it should give you the option of choosing HD settings. Quote Share this post Link to post Share on other sites
velocityphoto 0 #3 May 26, 2009 I created a new project , changed the format to wide screen 720 in there and it looks normal now. I'm assuming thats the only option there, for the hd project. A friend will bail you out of jail , a REAL friend will be sitting next to you in the cell slapping your hand saying "DUDE THAT WAS AWSUM " ................ Quote Share this post Link to post Share on other sites
beowulf 1 #4 May 26, 2009 Ok, I am home now and can give you more specifics. Create a new project and set it to blu ray disk instead of DVD. Then it will give you the options you are looking for. I generally use the AVC 1440x1080 60i. I choose those settings because I want to write to a DVD so it will play on my Blu Ray disk player in high definition. Here is a screen capture of what I select. Quote Share this post Link to post Share on other sites
velocityphoto 0 #5 May 26, 2009 Thanks I'll be doing another hd tonight . :) A friend will bail you out of jail , a REAL friend will be sitting next to you in the cell slapping your hand saying "DUDE THAT WAS AWSUM " ................ Quote Share this post Link to post Share on other sites
DSE 5 #6 May 26, 2009 you can access a similar menu by choosing FILE | Properties as well. Quote Share this post Link to post Share on other sites
bdazel 0 #7 May 28, 2009 How exactly do you burn the HD content to a DVD? Won't DVD Architect encode the file to an SD mpeg before creating the DVD? Quote Share this post Link to post Share on other sites
DSE 5 #8 May 28, 2009 Only if you tell it do. If the master source is AVC, then it'll burn those files without any recompression, unless you specify in the project properties that it should be SD. Then...it will be kinda ugly using AVC low bit source recompressed for SD MPEG2. Quote Share this post Link to post Share on other sites
beowulf 1 #9 May 28, 2009 Blu Ray disc players can read AVCHD off of DVD's and play it in HD. other then that read DSE's post. Quote Share this post Link to post Share on other sites
bdazel 0 #10 May 28, 2009 Thanks. So then is rendering and burning an AVC file the best way to make an HD DVD playable on a Blue Ray player? Can you still add multiple scenes and menus and such to the DVD? I don't have a Blue Ray player, or I would just test all this out w/o having to ask the questions. Quote Share this post Link to post Share on other sites
beowulf 1 #11 May 28, 2009 If you don't have a Blu Ray disc writer and don't want to fork out the cash for the blank media then yes it's the best way create discs that a Blu Ray disc player can read and play in HD. With DVD Architect 5 you can create an AVC disc on a DVD with menu's and everything just like a regular mpeg2 DVD. It won't play on anything except a Blu Ray disc player. Quote Share this post Link to post Share on other sites
bdazel 0 #12 May 28, 2009 Perfect. Thank you. Quote Share this post Link to post Share on other sites
