CKSCUBA
please help for canon settings
i have a new Canon xti with the 10-22 canon lens. I also have an hc40 with the royal diamond .3 lens.
what setting should i have the camera on like fast aport setting or some other setting and also what number should i set the lens to match the.3 lens like 14mm?
any help or advice would be appreciated.
thank you
chris
thank you
chris
I dont understand why people dont think about taking pictures on the ground.
Here's what I would do:
estimate the approx distance that you expect to be from your subject in the sky. Now use any other fixed object like a chair or a wall as your subject now take a picture and match the zoom to your video lens.
It helps to have your video camera in your hand so you can turn it on and view the "scene."
As far as settings go. I am 100% positive that if you do a search you'll find a shitload of helpful advice.
My advice is to read those posts and dont be afrid to snapp a few thousand pictures on the ground. go out side and take close-ups of flowers, take landscape shots learn the difference by using MANUAL settings.
Then when you get the hang of it you'l be able to tweak your camera for most situations.
dont forget to learn about the sunny 16 rule
My photos
My Videos
Oh ... you mean learn as much as you can about the science/art of photography itself?
That's a novel concept, indeed! :P;)
