rmsmith 1
A properly fitted harness is all you really need. Adjusting the four-point junction an inch or two can yield dramatic results in comfort. However, since you are shopping in the used market, the hardware will probably help you to get a more comfortable fit from a harness that was built around someone else. From an economic position, you will probably pay more for a rig with hardware, but it will also have better resale value and faster turn-over as these "goodies" are currently in demand.
Chest rings let me tighten the chest strap real tight and doesnt kink the harness. Keeps the MLW flat against the body. Feels like it would help keep the handles from folding under, but maybe Im reaching now.
Johnny
--"This ain't no book club, we're all gonna die!"
Mike Rome
Johnny
Mike Rome
sducoach 0
Best choice? Ford and Chevys. Go try both. Just remember if I see you with one of those little bungie straps I'll snap it!
Blues,
J.E.
James 4:8
Motab 0
I know it's dumb, but it's just one of those little nagging pseudo-fears I have... and I've never asked before, so I figure I should... Are the rings that make an articulating harness any more prone to breaking than a normal harness? It just seems like there would be an awful lot of stress placed on that steel... Just curious to hear what people have to say about that.
I'm not not licking toads....
Rob,
I've also found that articulated harnesses help translate body movements to the canopy (i.e. shifting weight left, turns left...sorry, having trouble typing my thoughts/my point tonight), more then non-articulated.
PhreeZone 20
If I remember correctly the rings are rated at 5000 pounds before distortion, the webbing is only rated to 4000. If you reach 4000 pounds of force on your body I think you have bigger things to worry about then if the ring distorts... Some manufactors use the RW8 rings that are the same as the ones used in the 3 ring assembly. If your worried about them distorting or breaking then you might want to consider another release system.
Yesterday is history
And tomorrow is a mystery
Parachutemanuals.com
Quote. The rings are the same as the ones used in the 3 ring assembly
Not always (eg the Atom by Parachutes De Freedom)
____________________
Say no to subliminal messages
masher 1
The rings used by Mirage are different too, I think.
Arching is overrated - Marlies
QuoteIf I remember correctly the rings are rated at 5000 pounds before distortion, the webbing is only rated to 4000. If you reach 4000 pounds of force on your body I think you have bigger things to worry about then if the ring distorts... Some manufactors use the RW8 rings that are the same as the ones used in the 3 ring assembly. If your worried about them distorting or breaking then you might want to consider another release system.
The 5010 ring (circular, the old base ring on early 3 ring systems) is rated at 2500 lbs as are cadmium or nickle plated RW 8's. Type 7 webbing is rated at 6000 lbs, type 8 webbing at 4000 lbs, the thread is rated at 40 lbs and a standard 3" stitch pattern is aproxamatly 5500 lbs. All of the destructive testing I have done and witnessed on harness segments caused failure at the edges of the stitch patterns not the hardware. Oh I almost forgot, the MS22040 leg strap buckles are also rated at 2500 lbs. Hope this helps
Deleted 0
All I have to say is...once you jump an articulated harness, you don't want to jump anything else.
sducoach 0
![[:/] [:/]](/uploads/emoticons/dry.png)
Blues,
J.E.
James 4:8
weid14 0
Personally I don't see a real benefit to chest rings, but there doesn't seem to be a downside either; maybe someone who likes them will pipe in on that.
I have found (in 4way anyway), that the chest rings make 10-14 jumps per day, much more comfortable. (yes, all rigs custom). Especially in the door trying to get all scrunched up for exits.
I have found things to be different than Aggie with respect to canopy input though. if I leave the chest strap tight, the articulated harness (chest rings), move more and it's harder to get a response. Of course loosening the chest strap creates a straight line up the harness, and it becomes a moot point.
I see it more of a weight transfering more directly to the MLW instead of binding against the laterals, if it wasn't an articulated harness. Its not just geometry, its seeing things as part as a whole system.
Its also something I've experienced. I personally think that a lot of people miss out on that since they tend to buy articulated when they buy their own gear, and once they get up to a wingloading in which harness input really plays a very direct role on canopy flight, they're not going to fly a non-articulated harness again, thus not feeling the difference.
Sorry that was so "rambily" let me know if it didn't make sense.
pchapman 281
A couple other minor issues to note:
1) Hip rings vary in their design depending on manufacturer and length of harness and container. Some rigs have the ring between the leg straps and the main lift web, while the lateral strap to the backpad of the container is a webbing junction higher up. On other rigs, the ring does also connect to that lateral strap.
Either way, the front and back part of the leg straps may or may not articulate relative to each other where they connect to the ring.
Which method is best, I can't comment on with any authority.
2) I'm guessing hip rings would be of even more benefit to someone short. On a short person's non-articulated rig, the stiff sewn junction for the leg straps starts just below the cutaway and reserve handles. For a taller person's rig, there's a few inches more webbing in between those two points, so even without rings, there's a lot more flexibility in the harness.
You don't need rings, but they make the harness more comfortable.
They're for anyone.
Articulated can refer to either hip rings or hip and chest rings. Hip rings are metal rings joining the leg straps (and on some containers also the laterals) to the main lift web. Chest rings are metal rings inserted into the main lift web; the chest strap comes off these rings.
Hip rings allow the leg straps to move seperately from the rest of the harness; makes you more comfortable on the ground, in the plane, and under canopy, and some jumpers say they notice a difference in freefall too.
