Kynan1
Best Flash for a Canon XTi?
6 in rapid seccession? You are looking for something along the lines of a Speedlight 580, but all flashes recycle rate depends on a few factors including battery power and distance to object you are shooting. The 580 can recycle in .1 seconds with fresh batteries and a close object that is in constant focus but with used batteries you are looking at up to 6 seconds. Depending on the object you are shooting and how much power the flash is having to use when it fires you are looking at getting as little as 100 flashes out of the batteries or up to 700.
Get rechargable batteries, you'll eat batteries otherwise.
Yesterday is history
And tomorrow is a mystery
Parachutemanuals.com
I would recommend a 580EX II... and if you really want a rapid refresh rate then you can get an external battery. For skydiving you are likely primarily going to be using the flash for fill (since it's generally done in the daytime.) so the flash can be run at a reduced power which will improve the refresh rate.
I haven't used my flash for skydiving yet so take my advice with a grain of salt... I have played with it on the ground a lot though... :$
Livin' on the Edge... sleeping with my rigger's wife...
He was talking about the flash.
Kynan, I dont use flash but Eventually I would like to build a helmet with one.
If you go to sahara camera center on eastern n(and sahara,DUH) those guys know alot and are always willing to talk.
they can give you the run down of speeds and models.
My photos
My Videos
So was I... though I only have the 580EX flash. Canon just came out with an updated version of that flash... the 580EX II which has a faster refresh rate and is designed to be more durable/water tight/etc to bring it more in line with the Canon 1D series of cameras.
(unless you were making a joke... in which case I appoligize for being ignorant... :$:D and er... Good One... :P)
