drudchen 0 #1 August 6, 2007 Does anybody know if a PC1000 could fit into a 2kc FF2 helmet that is made for pc101? Comparing the cameras side by side, it looks like the 30mm lens ring is on the exact same level, but the whole pc1000 camera is 0.7-1cm taller. Does anyone have a ff2 for 101 and can take a look how much gap is there in the top between the camera and the cover? Quote Share this post Link to post Share on other sites
Miami 0 #2 August 6, 2007 It almost certainly will...the plate the camera mounts on is adjustable, so even if the pc1000 is taller you can drop the plate to compensate. The biggest problem you might run into is that the cutout for the buttons on the back of the box may not line up exactly with the buttons on the pc1000, which is minor at most.Miami Quote Share this post Link to post Share on other sites
BillyVance 35 #3 August 6, 2007 QuoteIt almost certainly will...the plate the camera mounts on is adjustable, so even if the pc1000 is taller you can drop the plate to compensate. The biggest problem you might run into is that the cutout for the buttons on the back of the box may not line up exactly with the buttons on the pc1000, which is minor at most. Easily fixed. Make the cutout bigger."Mediocre people don't like high achievers, and high achievers don't like mediocre people." - SIX TIME National Champion coach Nick Saban Quote Share this post Link to post Share on other sites
Miami 0 #4 August 6, 2007 Quote Easily fixed. Make the cutout bigger. Exactly.Miami Quote Share this post Link to post Share on other sites
