dthames 0 #1 December 23, 2011 The SIM text describes how left and right hand pattersn should coexist on the same field.....jumpers turning away from each other. But a couple of pages later, a drawing shows jumpers turning toward each other. That looks like a contradiction to me. Can someone explain, if it is not? SIM section 4-3 C 6. Planning a landing pattern (intended landing area or alternate) for smooth flow and separation of traffic (see illustration above): a. Jumpers on left-hand (left-turning) approaches should land on the left side of the landing area; jumpers on right-hand approaches should land on the right side of the landing area to prevent conflicts. b. The turn from base leg to final is the most hazardous because of opposite approaching traffic c. See and avoid.Instructor quote, “What's weird is that you're older than my dad!” Quote Share this post Link to post Share on other sites
dthames 0 #2 December 23, 2011 I added my modified version if what I was envisioning. I switched patterns from left to right, to agree with what I understand the text and the caption on the drawing says. See attached.Instructor quote, “What's weird is that you're older than my dad!” Quote Share this post Link to post Share on other sites
quade 4 #3 December 23, 2011 You seem to be confused by thinking they should be used simultaneously. This is absolutely not the case. For whatever direction the landing pattern is set one or the other is appropriate. The default is left, but the physical layout of the landing area at a particular drop zone may require it to be right. For instance, imagine a drop zone that had an aircraft runway located close to the landing area. It would be completely inappropriate for any part of the parachutist's approach below 1000 ft be over the runway, so that might force a change. This is the case at Perris (see attached). The green strip of grass just to the east of the runway is the main landing area. Obviously flying over the runway below 1000 feet is a BAD idea. Skydivers landing to the north use a right traffic pattern. When they land to the south, they use a left traffic pattern.quade - The World's Most Boring Skydiver Quote Share this post Link to post Share on other sites
Hellis 0 #4 December 23, 2011 That looks like a very good idea, but in reality it seems very hard. First those lines must be either marked in some way so that noone enters the no fly zone or crosses the lines. Second, you need a massive landingarea. If we esimate a 20 second canopy ride in the baseleg, canopys will travel aprox 200 m. Thats 200 m for left landing pattern and 200 m for right landing pattern. And then you need at least 50 m of no fly zone on each side, plus ~50 of "straight in" landing area. That means you need at very minimum 550 m of landingarea. And this landingarea can not cross the runway. Then you might need a seperate HP landing area? Looks good on paiper but I'm not sure it can be done in real life. Even our "huge" landingarea will not be enough for that. Quote Share this post Link to post Share on other sites
SethInMI 174 #6 December 23, 2011 I think the SIM text and drawing do intend for left and right to be used at the same time. 6b says the "The turn from base leg to final is the most hazardous because of opposite approaching traffic" implying both can be going at once. IMHO, they show the bases coming together because that is how people would be flying when "forced" into using both patterns. Usually there is a preferred pattern direction and entry point, and only if one cannot reach the preferred point would one fly the other pattern. So having the two patterns start from the basically the same point makes having/allowing both totally redundant. Most DZs do not allow left and right patterns together in the same landing area regardless of where you land. But occasionally you may see people who cannot get to the preferred entry point to fly the correct pattern direction land with the opposite pattern rotation on the edge of the main area like the SIM drawing shows. SethIt's flare not flair, brakes not breaks, bridle not bridal, "could NOT care less" not "could care less". Quote Share this post Link to post Share on other sites
quade 4 #7 December 23, 2011 QuoteI think the SIM text and drawing do intend for left and right to be used at the same time. I haven't cracked open the SIM in awhile. I just did. Let me say that is the stupidest idea I've ever heard of in terms of a Main Landing area, but makes some sense if setting up completely separate Main Landing and Swooping areas. I can't think of any drop zone that would operate their main landing area that way.quade - The World's Most Boring Skydiver Quote Share this post Link to post Share on other sites
dorbie 0 #8 December 23, 2011 QuoteQuoteI think the SIM text and drawing do intend for left and right to be used at the same time. I haven't cracked open the SIM in awhile. I just did. Let me say that is the stupidest idea I've ever heard of in terms of a Main Landing area, but makes some sense if setting up completely separate Main Landing and Swooping areas. I can't think of any drop zone that would operate their main landing area that way. Take a look at Elsinore's adjacent landing patterns for the peas and student area and you'll believe this and more. Quote Share this post Link to post Share on other sites
dthames 0 #9 December 23, 2011 QuoteQuoteI think the SIM text and drawing do intend for left and right to be used at the same time. I haven't cracked open the SIM in awhile. I just did. Let me say that is the stupidest idea I've ever heard of in terms of a Main Landing area, but makes some sense if setting up completely separate Main Landing and Swooping areas. I can't think of any drop zone that would operate their main landing area that way. Thanks. I was not suggesting we do this next Saturday. I just want to make sure I understand what I am reaading. Maybe someone that works on the SIM could review this section. Listen to the instructors for the local DZ would be the standing rule, I guess. DanInstructor quote, “What's weird is that you're older than my dad!” Quote Share this post Link to post Share on other sites
Squeak 17 #10 December 23, 2011 QuoteQuoteI think the SIM text and drawing do intend for left and right to be used at the same time. I haven't cracked open the SIM in awhile. I just did. Let me say that is the stupidest idea I've ever heard of in terms of a Main Landing area, but makes some sense if setting up completely separate Main Landing and Swooping areas. I can't think of any drop zone that would operate their main landing area that way. out main landing area is split by our runway, the duel pattern works fine for us. It also helps prevent people from crossing an active runway under canopyYou are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
quade 4 #11 December 23, 2011 Quote . . . the duel pattern works fine for us. That is perhaps a better name for it. Do you guys use pistols to shoot down opposing traffic? In all seriousness though, if the landing areas are split by the runway, I can't see any other way of doing it, but then again, that's also not a normal configuration for a drop zone.quade - The World's Most Boring Skydiver Quote Share this post Link to post Share on other sites
nigel99 634 #12 December 23, 2011 Quote Quote . . . the duel pattern works fine for us. That is perhaps a better name for it. Do you guys use pistols to shoot down opposing traffic? In all seriousness though, if the landing areas are split by the runway, I can't see any other way of doing it, but then again, that's also not a normal configuration for a drop zone. The farm has a right hand pattern for the alternative landing area and left for the main. There is also a very clear demarcation between the two areas (road lined by trees). So I think it may be more common than you think. It probably only works where a dz has a 'proper' landing policy and not based on first man down...Experienced jumper - someone who has made mistakes more often than I have and lived. Quote Share this post Link to post Share on other sites
sundevil777 102 #13 December 24, 2011 QuoteI think the SIM text and drawing do intend for left and right to be used at the same time. 6b says the "The turn from base leg to final is the most hazardous because of opposite approaching traffic" implying both can be going at once. IMHO, they show the bases coming together because that is how people would be flying when "forced" into using both patterns. Usually there is a preferred pattern direction and entry point, and only if one cannot reach the preferred point would one fly the other pattern. So having the two patterns start from the basically the same point makes having/allowing both totally redundant. Most DZs do not allow left and right patterns together in the same landing area regardless of where you land. But occasionally you may see people who cannot get to the preferred entry point to fly the correct pattern direction land with the opposite pattern rotation on the edge of the main area like the SIM drawing shows. Seth If a DZ has landing areas on both sides of a runway (and landing direction is same as the runway), for example, and everyone chooses to land on one side or the other at a decent altitude (as the should - not crossing the runway below 1k), then having both R&L patterns going could make sense to me.People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
DSE 5 #14 December 24, 2011 QuoteYou seem to be confused by thinking they should be used simultaneously. This is absolutely not the case. For whatever direction the landing pattern is set one or the other is appropriate. The default is left, but the physical layout of the landing area at a particular drop zone may require it to be right. For instance, imagine a drop zone that had an aircraft runway located close to the landing area. It would be completely inappropriate for any part of the parachutist's approach below 1000 ft be over the runway, so that might force a change. This is the case at Perris (see attached). The green strip of grass just to the east of the runway is the main landing area. Obviously flying over the runway below 1000 feet is a BAD idea. Skydivers landing to the north use a right traffic pattern. When they land to the south, they use a left traffic pattern. I can think of at least 3 dropzones that have painted concrete blocks or similar to mark a split in the field, LH on one side, RH on the other. I don't care for it, but that's how a few do it. Quote Share this post Link to post Share on other sites
popsjumper 2 #15 December 24, 2011 QuoteI added my modified version if what I was envisioning. I switched patterns from left to right, to agree with what I understand the text and the caption on the drawing says. See attached. The text matches the pic correctly. Your mod doesn't. SIM shows worst case. Your mod is better...up to point. Your downwind leg would have to be very narrow. Both patterns at the same time is not as unusual as some would think.My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
virgin-burner 1 #16 December 28, 2011 Quote Quote . . . the duel pattern works fine for us. That is perhaps a better name for it. Do you guys use pistols to shoot down opposing traffic? no set pattern where i jump; and since we're no yankee cowboys, we use common sense and look out for each other, no pistols needed. works fine for us too.“Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
popsjumper 2 #17 December 28, 2011 Quote no set pattern where i jump; and since we're no yankee cowboys, we use common sense and look out for each other, no pistols needed. works fine for us too. So, maybe it's a better idea that you guys stay at home then. There's good reasons for landing patterns and most DZ use them.My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
DaVinciflies 0 #18 December 28, 2011 Quote no set pattern where i jump; and since we're no yankee cowboys, we use common sense and look out for each other, no pistols needed. works fine for us too. Have you considered a career in diplomacy? I don't think "winging it" is something to be proud of, and crowing about it is not helping those if us who are trying to change the culture of canopy control to the point where people are proud to be predictable and controlled. Once again your off-the-cuff attempts at comedy might have been better kept to yourself. Quote Share this post Link to post Share on other sites
virgin-burner 1 #19 December 28, 2011 "winging it", docpop? comedy? you're the joke here, baby..“Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
Remster 30 #20 December 28, 2011 Quote Quote Quote . . . the duel pattern works fine for us. That is perhaps a better name for it. Do you guys use pistols to shoot down opposing traffic? no set pattern where i jump; and since we're no yankee cowboys, we use common sense and look out for each other, no pistols needed. works fine for us too. Maybe it's just your DZ that's backwards. Or you simply dont even know the rules where you jump. All the European DZs I jumped at had patterns.Remster Quote Share this post Link to post Share on other sites
virgin-burner 1 #21 December 28, 2011 other than mine, most do have.. *** ** *** ***** *********** **** ***** ********* ** **** *** *****, ** *** **********! have a nice day!“Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
DaVinciflies 0 #22 December 28, 2011 Quote"winging it", docpop? comedy? you're the joke here, baby.. Quoteother than mine, most do have.. *** ** *** ***** *********** **** ***** ********* ** **** *** *****, ** *** **********! have a nice day! You're proving my point EXACTLY. Stop acting like a dickhead, you're devaluing these threads. Quote Share this post Link to post Share on other sites
virgin-burner 1 #23 December 29, 2011 you like attacking me, docpop!? your contribution is SOOO valuable. wow, i'm blown back, honestly, i'd love to have your insight! can i hold your dick?“Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
riggerrob 643 #24 December 29, 2011 Children! Children! Please play nice. Quote Share this post Link to post Share on other sites
jacketsdb23 49 #25 December 29, 2011 Our dz uses dual patterns to separate main landing area and swooping area as quade suggested. Works well for us. Main landing area is left hand pattern, swooping area right hand pattern. (Winds light/variable, from the north, or from southwest)Losers make excuses, Winners make it happen God is Good Beer is Great Swoopers are crazy. Quote Share this post Link to post Share on other sites
