dominicc 0 #1 April 17, 2007 Hi Have you try the sony DCRHC96 for skydiving? Maybe a bit wide if I want to use it on the side of my hemet? Any info about that cam? thank's dom Quote Share this post Link to post Share on other sites
dragon2 2 #2 April 17, 2007 Yes it's being used for skydiving. Topmount it not sidemount it it's too wide. ciel bleu, Saskia Quote Share this post Link to post Share on other sites
bigdad510 1 #3 April 19, 2007 I have one and use it for skydiving. It is a bit wide. I tried it side mounted and it sticks out too far. I have mine mounted on a Skydance Sonic. I can fit both the 96 and a Digital Rebel mounted on the top side by side. I started with the HC36, and it was very good, but had no LANC. But the 96 does. It shoots great video. I use manual focus on sports mode, witha .45 wide angle lense, and it works great!Brad Quote Share this post Link to post Share on other sites
ncfitzge 0 #4 May 4, 2007 I use my 96 as a side mount and it isn't too bad. Check out the Cookie helmets for it.#148 Sonic Scrat "Have you ever kissed a rabbit between the eyes?" Woodpecker pulling out his pants pockets to the waitress Quote Share this post Link to post Share on other sites
phoenixlpr 0 #5 May 8, 2007 Quote I use my 96 as a side mount and it isn't too bad. Its only 72mm wide as naked. Quote Share this post Link to post Share on other sites
bigdad510 1 #6 May 8, 2007 I agree, way to wide to be side mounted. I jumped the 36 (same size) side mounted "once" and that's all i took to convince me to top mount it.Brad Quote Share this post Link to post Share on other sites
The111 1 #7 May 8, 2007 QuoteI agree, way to wide to be side mounted. I jumped the 36 (same size) side mounted "once" and that's all i took to convince me to top mount it. I think the 96 is about 1/4" wider.www.WingsuitPhotos.com Quote Share this post Link to post Share on other sites
