propilot 0 #1 September 10, 2006 I have Adobe Premiere Pro 7.0 and my camera (PC1000) is not listed in the dropdown box when I try and set up capture. Am I stuck with having to buy an old camera so I can get my tape onto the computer? Is there some kind of update I can get? Quote Share this post Link to post Share on other sites
PhreeZone 20 #2 September 10, 2006 The camera is much newer then that old version of Premiere. Just use the Generic DV capture driver and it should work.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
Mikki_ZH 0 #3 September 11, 2006 I have a simular problem to record from my HC3 camera in HD format with Premiere Pro 7.0. This does not work, I can only record if I downgrade it to normal DV format. Does anybody know how I can record in HD format?Michi (#1068) hsbc/gba/sba www.swissbaseassociation.ch www.michibase.ch Quote Share this post Link to post Share on other sites
mccordia 74 #4 September 11, 2006 QuoteI have a simular problem to record from my HC3 camera in HD format with Premiere Pro 7.0. This does not work, I can only record if I downgrade it to normal DV format. Does anybody know how I can record in HD format? download the HDV update from adobe.com which enables you to capture/edit and export HDV.JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
dragon2 2 #5 September 11, 2006 Then you can still do only file chunks, not scene detect. I finally resorted to a freeware tool called HDVSplit to split the files from the tape, then i import those into Premiere. You'd think Premiere Pro 2.0 could freaking handle hdv files better Other workaround if capture tape in dv first, export batch list, capture tape again in hdv. Too much work I now have to re-do most of the work on the Bussloo video because the original 5-30 mins hdv files (captured with PP 2.0) are too big or something, and premiere refuses to render And I'm using a brand new laptop with dual core processor and 2 gig of ram too ciel bleu, Saskia Quote Share this post Link to post Share on other sites
mccordia 74 #6 September 11, 2006 Saskia, if you already knew your end result will only be used on DVD and Web, why dint you edit it in normal broadcast res. straight away then?JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
FeFe 0 #7 September 11, 2006 because hdv is cool, i guess Quote Share this post Link to post Share on other sites
dragon2 2 #8 September 11, 2006 Because i need the extra resolution for this ciel bleu, Saskia Quote Share this post Link to post Share on other sites
propilot 0 #9 September 17, 2006 You mean in the drop down box? Or do I have to go online and find a new driver? Quote Share this post Link to post Share on other sites
