pierre3636
Sony V3 7meg still camera
Quick question is there anyone out there using a V3? I'm trying to get mine setup for still shots in freefall...If you do - what type of bite switch are you using ? And do you set the camera on manual or auto focus ? I'm having some issues but then again im pretty inexperienced when it comes to stills
~ time is ~ time was ~ times past ~
I am use a Sony V1. I bought the remote for the camera which is quite big and had other functions on it. I then took it apart, cut out the other buttons and then glued one button on top of the one for taking stills. I also cut the case for the remote down as small as possible. I then took a balloon and incased it. I use it as a tongue switch putting the entire thing in my mouth. It takes a little to get use to it but since the remote in more of a lanc controler with a circuit board and chips on it I did not see any way around it. If I remember I will take a picture of the switch enclosed in the balloon.
Kirk
here is a link to sony's remote
http://www.sonystyle.com/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/USD/SY_DisplayProductInformation-Start?ProductSKU=RMVD1
