incode
Help with premiere pro export
When i export video from prem pro the music always seems to crackel, any ideas what this could be?
edit= Also when exporting using the new divx 6.2.5 in hgh def muli pass with a bit rate of 3000 in insane quality i just get a black image.
You've likely exceeded 0dBFS in your output. Are you viewing meters in VU or FS mode?
Digital audio has no forgiveness, your max level shouldn't be higher than -03dB, and not even that if you think your DVDs will be playing on older, oversampled DVD players. Leave yourself a minimum of 1dB headroom at most times.
You might try downloading the demo of iZotope, it will work in Premiere for 2 weeks, and that will really help get your audio tamed down.
Thanks i just droped the audio to -0.72 and it seems to work fine :P
also to add to the first post when i try and code in divx using 1 pass it works but just comes out in really bad quality, when I run 2 passes it just comes out black
