The111 1 #1 July 14, 2006 I use Irfanview's batch operations to resize groups of jpegs quickly. But it only allows resize by scale (dimensions). When resizing a set of photos to post on DZ.com, for example, I aim to get each one just <120kb. Anybody know of a program which can batch resize with a filesize as the target? Currently not only do I have to do the files one by one, I have to do them more than once as it takes more than one iterative guess to get the right size.www.WingsuitPhotos.com Quote Share this post Link to post Share on other sites
DSE 5 #2 July 14, 2006 Yeah...a tad kludgy, but it works well. RW Designer makes a droplet that you'll put on your desktop. Open Explorer and the folder of images. Then sort your images by size. Then drag images to droplet. It'll process them all in order, starting with largest or smallest first. It only resizes to one size, not percentages of original size. ACDSee older versions did it by percentages and original size, sortable however you wanted, name, size, date, dims...but they killed that in later versions. If you can find an old version like 2.0, you'd have it good Quote Share this post Link to post Share on other sites
