iflyfree 0 #1 September 23, 2005 I was wondering if i should get a .3x or a .5x lens for tandem video Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #2 September 23, 2005 You really don't need anything tighter than a .5 for tandem video. I jump a .3, but zoom it out to about .45 for the skydive portion of the video. Quote Share this post Link to post Share on other sites
flow 1 #3 September 23, 2005 I've used .42 and .3 and prefer the .42. Most of the time I fly in the grip distance but .42 gives better view of the passenger. Why? My .3 is a fisheye lens and I like the clearer and not so bent image .42 produces for tandems... Quote Share this post Link to post Share on other sites
Canuck 0 #4 September 23, 2005 Go .5 (or something equivalent) for tandems. I've used a .3 on a few tandems and didn't care for it much. It's just wider than it needs to be for the job. A big problem with a video lens that wide is that it becomes very difficult to match a still lens (without spending a gagillion dollars) and having incompatible lenses really sucks. If you're not shooting stills, then it's less important, but there is still no reason to go that wide for tandems. Canuck Quote Share this post Link to post Share on other sites
EricTheRed 0 #5 September 23, 2005 My vote is also .5x Less distortion, plenty wide for tandems and 4 way IMOillegible usually Quote Share this post Link to post Share on other sites
garywainwright 0 #6 September 23, 2005 Also remember that a conversion lens does exactly that - converts what you already have. My Old PC10 is significantly wider than my PC101http://www.garywainwright.co.uk Instagram gary_wainwright_uk Quote Share this post Link to post Share on other sites
pcalandra 0 #7 September 24, 2005 I also recomend a .5, I don't like the distortion of the .3. Quote Share this post Link to post Share on other sites
riggerrob 644 #8 September 24, 2005 No distortion on www.royal-lens.com's 0.3 wide-angle lenses and only a tiny amount of distortion on their 0.2 lenses. 0.2 and 0.3 work great for Handy-Mount, however, those lenses are too wide for outside videographers. Outside videographers are better off with 0.4 or 0.5 lenses. Quote Share this post Link to post Share on other sites
AndyMan 7 #9 September 25, 2005 I use the Sony .6, which is actually wider than my Kenko .5. Your mileage may vary. _Am__ You put the fun in "funnel" - craichead. Quote Share this post Link to post Share on other sites
Canuck 0 #10 September 26, 2005 QuoteNo distortion on www.royal-lens.com's 0.3 wide-angle lenses The most perpetuated un-truth in the lens industry... I think the Roayl .3 is an OK lens, but there is very obvious distortion and bluriness around the edges of the images it produces. Canuck Quote Share this post Link to post Share on other sites
AndyMan 7 #11 September 26, 2005 QuoteQuote No distortion on www.royal-lens.com's 0.3 wide-angle lenses The most perpetuated un-truth in the lens industry... It's more than just an "un-truth", it's absurd. _Am__ You put the fun in "funnel" - craichead. Quote Share this post Link to post Share on other sites
Canuck 0 #12 September 26, 2005 I was just being gentle... Canuck Quote Share this post Link to post Share on other sites
AiRpollUtiOn 0 #13 September 27, 2005 If you're gonna do tandemvideo, you're gonna want to do stills as well. Figure out a good combination. I have a .5 and a .45 (Hama) on my sony PC-7 (can't figure out why it doesn't die on me, but I'm not fixing untill something is broken) The .45 works best for me, and I use it in combination with a .22 lens on a Canon rebel (analogue, we are still handing the rollsto the passengers...) The choice of the .45 has one main reason for me: little distortion, bu to get a screen filler, I need to be quite close, and I find it a lot easier to react to movements of the tandem pair when flying close to them. It also makes it (in comparison to the .5) easier for me to get the drogue in the shot, if you'll be sit- or backflying that shouldn't be a problem, but since I fly tandemvideos with a belly-down videosuit with wings I like the extra range. I have 2 main reasons why I don't go smaller (to something like the .3) 1) distortion 2) even if I get blown away a bit on exit, or if the drogue doesn't come out as fast as you would expect, the tandempair isn't a tiny dot on the screen. The smaller the number on your lens, the smaller things will appear on the screen when you're a bit further than where youu want to be. Two shots below are with the .22 lens, nearly no distortion."Don't make me come down there" - God. My site:http://www.skystudio.nl/video.html Some of my vids: http://www.youtube.com/user/TomSkyStudio Quote Share this post Link to post Share on other sites
FreeflyKiwi 0 #14 September 27, 2005 Dead right, figure out a good combo. I use a Kenko .42 and a Canon Fisheye 15mm combo Be aware that not only do some of the wider lenses distort, but some tanem instructers may not like you flying closer to compensate for the lense. I love my combo, my .42 is a fisheye and does distort but I like the effect and my 15mm takes amazing pictures and adds an artistic toach. Exit can look terrible if not flown tight. I have used a .5 in the past and thought is was a great size for tandem, in my opinion and from the other posters looks like the way you should go. Pictures are from my canon 15mm, shots are similar on my video cam.Dale two time New Zealand gumboot throwing champ. Quote Share this post Link to post Share on other sites
