BGill 0 #1 July 22, 2005 so im making my video on premiere. everything has been going great and it looks awesome, but when i export it into a .avi file, thats where i have a problem. the first 5 seconds of normal "in the plane" footage is fine but then the music kicks in over it. at that point it gets all crackly basically until the background noise fades out until its only the music playing. the rest of the video sounds fine. it's only music at that point though. does the fact that i have 2 audio files playing at full volume contribute to that? or is there some other reason for it? if it is because of the 2, how do i solve this while still being able to hear the music at a good loud level while still hearing the "in the plane" stuff? also, any recommendations on what audio settings i should be using for burning a DVD? thanks in advance for the help. Quote Share this post Link to post Share on other sites
alw 0 #2 July 22, 2005 You can mix audio in Premiere. I'd suggest you first try to crossfade the two sources using the constant power setting. If that doesn't work reduce the voume on one track while increasing it on the other (with the overlap. You can also split the audio and video tracks, export the audio, and work on it in a mixing program if you have one that you're comfortable with. It would help if you'd post what version of Premiere. 1.5 handles this a bit differently than previous versions by implementing key frames for sound and video. --------------------------------------------- Every day is a bonus - every night is an adventure. Quote Share this post Link to post Share on other sites
BGill 0 #3 July 22, 2005 i'm using premiere pro. i think i solved it, basically by turning down the volume on 1 of the 2 overlapping audio files so they weren't both at full volume, that seemed to get rid of the crackling. i guess, just like everything, a little tinkering around will solve it. Quote Share this post Link to post Share on other sites
jtval 0 #4 July 22, 2005 hey how do you keep the audio files from craklin all the time? the only way I can do it is by adjusting the volume to -5 on each clip. IMy photos My Videos Quote Share this post Link to post Share on other sites
BGill 0 #5 July 22, 2005 i just adjusted it down -2 or -3 and it got rid of the crackling. Quote Share this post Link to post Share on other sites
jtval 0 #6 July 23, 2005 ok, that seems to be universal. I forget which thread it was in but someone suggested importing as 48000. I've tried that and still got CrackleMy photos My Videos Quote Share this post Link to post Share on other sites
dragon2 2 #7 July 23, 2005 The sound from my camera when imported into premiere used to crackle. Problem seems to have gone away after changing the Audio Mode to 12 bit. ciel bleu, Saskia Quote Share this post Link to post Share on other sites
jtval 0 #8 July 23, 2005 Hm, thanks! I'll try thatMy photos My Videos Quote Share this post Link to post Share on other sites
mccordia 74 #9 August 1, 2005 http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=1588834;search_string=48.000;#1588834JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
