teamhypoxia
Premier/.avi help
anyone familiar with importing .avi files into Premier
I'm having trouble with the audio
everything I've read says that the audio should be conformed when imported but my audio tracks on the timeline are flat. any exporting i've done has been silent
if i play the sequence in the project window (itty bitty little window) i get audio, but the monitor window will not play audio
any ideas/suggestions ?
btw using premier pro 1.5
thanks
when you import a video or audio file PrePro will automatically conform it.
Im at work at the moment so dont have PP in front of me, but I will try and remember.
What you need to do is change the project playback settings.
By default, Adobe Premiere Pro previews audio through the DV device to external speakers only. If you change the audio playback to Play Audio on Audio Hardware, Adobe Premiere Pro plays audio through the computer's hardware and speakers.
To update the playback settings to play audio on audio hardware:
1. Choose Project > Project Settings> General.
2. Click Playback Settings.
3. Choose Play Audio on Audio Hardware.
4. Click OK to close the Project Settings dialog box.
--+ There are 10 types of people in the world: Those who understand binary, and those who don't.. --+
actually, I had done that. the waveform for the audio is simply flat. In fact, when I exported the project as an .m2v and a .wav it made a giant, silent .wav file
anyway, I tried the previous suggestion of ripping the audio from the .avi using virtualdub (actually used virtualdubmod) and that seems to have worked. at least I now have a viable audio file in my timeline. premier is exporting to dvd now so we'll see. what a collosal pain in the ass though! ripping the audio made a file that wasn't quite identical in duration to the video so it took a little tweaking to sync them back up. I wish I knew if I was buggering a setting in premier or something. I've never had any trouble capturing audio from my dv tapes at all, just this .avi
it is definitely something to do with premier, as i have had the same problem in the past. I just cant remember what caused it, or better still how i fixed it...
now let me think............
well this is laughable.......
so i take the files into work this morning on a portable hard drive and try to import them there. no such luck. they won't import at all (the avis). says "unsupported compression". I'm thinking it can't be a codec problem because the comp will play them with media player...... a suggestion on an online forum says "rename the .avi to .mpg, so I do that and try inporting again. this time it imports it but doesn't recognize it as a video file, just imports the audio. so now I have what I was originally after, a workable audio track, but no video. this crap is giving me a headache :P
