Skymonkey13
How thick?
If you're using it as any sort of bracket that will have to support weight out away from the helmet just using the metal's strength you'll want to bend the edges to give it a frame, a very solid platform. To bend the piece properly after bending the supports in the piece, you're going to have to either use a shrinker or make a couple of cuts on the supports. After you cut you'll either have to pop a couple of rivets in it on the support bends or you'll have to do some quick welding.
Not a big deal really, as long as you plan what you're doing and make it to plan.
