jose 0 #1 April 25, 2005 Has anyone here fixed a bad lanc port connection inside of a PC series camera? My 2nd 120 and this port has gone tits up as well. Quote Share this post Link to post Share on other sites
PhreeZone 20 #2 April 25, 2005 Mine's broke too and has been for 2 years so if you figure it out let me know Everything else works, just no LANCYesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
psw097 0 #3 April 25, 2005 It sucks - board mounted connectors, micro-fuses, etc. I've tried a couple times and made it worse at least once. If you can find the service manual (I don't have the PC120 manual) you can just replace the board but Sony charges almost as much as the flat rate so a lot of the boards. But that only works if the connector is the problem - one time I traced it past the connector to the interface and that was on a completely different board, I gave up there. Quote Share this post Link to post Share on other sites
lister55 0 #4 April 26, 2005 If you just sew a mirror on to your wrtist strap of your Alti then you dont need a LANC port. If you are only using it for the cam eye that is. Plus you can get some shots of yourself with the mirror!! Quote Share this post Link to post Share on other sites
