Squeak
Veiwing memory stick images
I transfered some JPG images from my computer to my camreas memory stick but for some reason I can't view them on the camera.
I've tried the 101 folder, new folders and no folders but I can only ever get the generic backround images that came with the camera, non of my images show up.
Any ideas on how to fix this?
The camera is a PC105e
My Life ROCKS!
How's yours doing?
I had the same problem.
I captured a few frames, then go into photoshop or the like and edit the image to what you want. then when you save it out, don't change the file name and make sure the jpeg is not progressive. It should sow up then.
Its tricky, but should work.
www.canopyflightcenter.com
www.skydivesac.com
www.guanofreefly.com
