Levin
wide angle lens for tandem stills & freeflying
i have a cannon eos rebel x still camera. what is a good lite weight lens to get. i'd like to stay under $300. prferably closer to $200.
also what is a good remote switch to use? i'd like a hand held push button type. i don't mind having to mess with running a cable under my jumpsuit and down my arm.
thanks
Take the 35mm equivalent from the PC5 manual and multiply it times .42 - that will tell you what lens will match your video. Here, I'll help. The manual says 42mm * .42 = 17.64mm
I use a Tamron 17-35/2.8-4. That way I can match any of my 3 wide angle converters with either my digital or analog still camera. The bonus is that its sharper, lighter, with better contrast that any of the primes I've owned. Its a lot more that 2 or 3 hundred though.
If he is using an adapter ring of any kind, that will move the W/A lens further from the camera, increasing the mag factor some. Also, if he is zooming in a touch to cut out the corners, there's another point or two of increased mag factor.
The 24mm will be closer to what he has, as well as lighter than a zoom.
Some zoom lenses don't hold up well to the stress of skydiving. I've only seen cheapie zooms used, so maybe a higher quality one would hold up better.
Dude Canon Makes a 15mm fixed lens that ROCKS for freeflying.. I am not sure about tandems but if youwant to get (SHots while you are in the formations) in freeflying you get everyone around with it, feet to head. You do have to be pretty close if shooting outside video and stills, but i like to be in the mix of things when taking shots anyways. it is a little over 300$ but man it is good.. semi-fisheye. You cant really notice though..
