cutaway1 3 #1 September 22, 2004 I just bought a pc-109, I cound not find a pc-105, does anybody know how to remove the attached strap without having to cut it, or is that the only practical way. I would appreciate any recommendations for the best wide angle lens for this camera for free flying. Thanks alot, TimSCR-21 Quote Share this post Link to post Share on other sites
melushell 0 #2 September 22, 2004 i cut the metal pin that is at te end of the strap and than u can take it off so u do't have to actually cut it but u will still have the small strap attached to the camera but i am quite happy with the small strap because i can add an extra attachement point in case that the others fail ( i use an L mounting) let me know if it works or maybe u wrecked it already Quote Share this post Link to post Share on other sites
BartsDaddy 7 #3 September 22, 2004 It's been awhile since I did mine and it is not in front of me now but you can remove a few screws and take it off the plastic handle and then reatach the plastic handle edited to add when I get home I will loke at mine and post how to do it----------------------------------------------------------------------------------------------- Handguns are only used to fight your way to a good rifle Quote Share this post Link to post Share on other sites
Cornholio 0 #4 September 22, 2004 QuoteIt's been awhile since I did mine and it is not in front of me now but you can remove a few screws and take it off the plastic handle and then reatach the plastic handle edited to add when I get home I will loke at mine and post how to do it----------------------------------------------------------------------------------------------- Yes, I did the same thing. You can remove the screws for one mount, and it comes off, but for the other one I just got a thread picker and picked out the threads on the strap so that I could sew it back together in the future - if a need ever presented itself. Then I cut the bracket and put some eopxy in the hole so dirt would not get inside. Works pretty good. Butthead: Whoa! Burritos for breakfast! Beavis: Yeah! Yeah! Cool! bellyflier on the dz.com hybrid record jump Quote Share this post Link to post Share on other sites
spidermonky 0 #5 September 23, 2004 Quotei cut the metal pin that is at te end of the strap and than u can take it off so u do't have to actually cut it but u will still have the small strap attached to the camera but i am quite happy with the small strap because i can add an extra attachement point in case that the others fail ( i use an L mounting) let me know if it works or maybe u wrecked it already That's what I did too and now I like it better without that little metal tip. Also I used a lighter to burn the end into a smooth unfrayed end. Quote Share this post Link to post Share on other sites dubbayab 0 #6 September 23, 2004 I have a PC 109, I found the philips head screws when I opened the tape compartment. Gaffers tape the memory stick input slot, and the rest of the screw holes. Don't forget... you may/probably will need an addaptor ring to align wide angle lenses to your camera, then gaffer tape that! Quote Share this post Link to post Share on other sites dixieskydiver 0 #7 July 24, 2005 I just did this and got it off great, just be careful not to unplug the little bronze plug to the sound board. It took me a little while to figure out how to get that sucker back on when I accidentally unplugged it. Dixie HISPA #56 Facil Rodriguez "Scientific research has shown that 60% of the time, it works every time." Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
