DaGimp 0 #1 July 5, 2004 I use the digutal Rebel and every so often I will get an outragious white balance for the entire jump. It looks like everything is whited out Now I have made a jump and all pictures came out fine, 20 mins later, same settings, same conditions, i get the whited out pics. Anyone know why????"Professor of Pimpology"~~~Bolas Quote Share this post Link to post Share on other sites
jdhill 0 #2 July 5, 2004 What lens are you using? JAll that is necessary for the triumph of evil is that good men do nothing. - Edmund Burke Quote Share this post Link to post Share on other sites
quade 4 #3 July 5, 2004 Does the software you use to view your photos allow you to look at the meta-data? Yes, I know you said you use the same settings for the photos, but maybe something -subtle- can be learned from looking at the settings. I'd also try to find out if there was some sort of pattern to the behaviour. My initial guess would be that maybe the meter is set in such a way that it's metering your first shot more or less correctly, but the rest of the frames are getting the same exposure and therefore overexposed. Maybe you're inside a tailgate and that's exposed correctly, but it locks on to the exposure setting and that would be obviously -way- to much light outside the aircraft. The same thing would happen if you were looking mostly at a black rig just before launch and if it locked on to that exposure for freefall.quade - The World's Most Boring Skydiver Quote Share this post Link to post Share on other sites
Deuce 1 #4 July 5, 2004 The Meta-Data states quite clearly that that is one FINE looking Wings container! Quote Share this post Link to post Share on other sites
pcalandra 0 #5 July 6, 2004 Is this what you are talking about? This has happened to me once, and I have no explanation as to why? It really pissed me off too Here is the metadata File Name IMG_0472.JPG Camera Model Name Canon EOS DIGITAL REBEL Shooting Date/Time 6/19/2004 6:46:08 AM Shooting Mode Shutter Speed Priority AE Tv( Shutter Speed ) 1/125 Av( Aperture Value ) 7.1 Metering Mode Evaluative Exposure Compensation 0 ISO Speed 200 Lens 18.0 - 55.0mm Focal Length 28.0mm Image Size 3072x2048 Image Quality Fine Flash Off White Balance Auto AF Mode AI Focus AF Parameters Contrast +1 Sharpness +1 Color saturation +1 Color tone Normal Color Space sRGB File Size 796KB Drive Mode Continuous shooting Owner's Name Camera Body No. 1060310189 Quote Share this post Link to post Share on other sites
quade 4 #6 July 6, 2004 Just from looking at the image it looks like the iris is stuck all the way wide. Over exposed & no depth of field . . .quade - The World's Most Boring Skydiver Quote Share this post Link to post Share on other sites
pcalandra 0 #7 July 6, 2004 That's what I thought but the metadata indicates F7.1? Quote Share this post Link to post Share on other sites
quade 4 #8 July 6, 2004 Maybe 7.1 was what the camera asked the lens to do . . . it just didn't do it.quade - The World's Most Boring Skydiver Quote Share this post Link to post Share on other sites
newshooter12 0 #9 July 6, 2004 Pat which lens do you have on it? Is it the one that comes with the kit? matt Quote Share this post Link to post Share on other sites
pcalandra 0 #10 July 6, 2004 The standard kit lens, and this is the only time I've exprerienced this in over 1,000 exposures so far. Hopefuly this is the last time too! Quote Share this post Link to post Share on other sites
genoyamamoto 0 #11 July 6, 2004 Intermittent issues most likely point to dirty/stuck electrical contacts. Check to make sure that all of the contacts are clean on both the lenst and the camera body. Sometimes the contact balls on the body stick, so clean those and make sure they don't get stuck when they get pushed down. Also check to make sure the lens mount is secure. Those kit lenses don't seem like the sturdiest lenses out there. If there is any excessive play in the lens mount, you could get intermittent electrical contact, and "fix" it after a jump when you are handling the camera. Gotta go... plaything needs to spank me Feel the hate... Photos here Quote Share this post Link to post Share on other sites
blazetailman 0 #12 July 6, 2004 I would do a few test pictures on the ground. Normal sunny day set the exposure manually at 350 f16-11@iso 200. This should work 90% of the time. The old sunny daylight rule. rarely has this ever let me down. The sun is a consistent light source. 125 f16 @iso 100. so take some shots on the ground, out the plane window on the way to alitude and see how the pic looks. Make minor corrections and shot the jump in manual and not tv and see what the results are. The should be better than tv.www.canopyflightcenter.com www.skydivesac.com www.guanofreefly.com Quote Share this post Link to post Share on other sites
