NoPush
Sony HC85 in BoneHead's TRV Box - Heads up
Hey everyone,
Heads up on mounting a DCR-HC65 or HC85 in BoneHead's TRV Box for the TRV50/80 series.
You will need to put a 1/2-in plate in the bottom of the D-Box to raise the camera for a proper fit. I used a cheep plastic cutting board and cut a plate about 5 1/2 by 2 3/8 inches. Remove the foam pad on the bottom of the D-Box and mount the plate. I mounted the plate as part of the D-box by extending the screws to 3/4-in from the 1/4-in provided by BoneHead and used the flat nuts provided BoneHead. Use a 3/4-in Flat Boring bit for wood to recess the flat nuts flush with the plate. A little extra foam than what is provided is also needed for a snug fit of the camera.
With the plate, the HC65/85 fits great in the D-Box.
Cheers!
I thought so too.......
Someone a while back emailed me the pic and I had a vinyl shop recreate it from a sticker I bought on the web.
Sums up how I feel in the plane waiting to get to altitude.
If his other hand was pointing to his head it would be a great logo for BoneHead.
My girlfriend got pissed when I put it on my helmet.......go fiqure...
I think it was called or titled Boneronie. Do a search.
Cheers!
